586,872 active members*
3,075 visitors online*
Threaded View
    Apr 2004
    99
    Old junk Makino Wire Cut
    I had an opportunity to own two set junk of Makino EDM wire cut, but not sure what will I do with them. Looks like all the junk still have the most of the parts. Here is the list:
    - Two set of Main unit
    - Two set of Makino MGW-15 Controller
    - Two set of Fanuc 200C Controller
    - Two set of Display Unit for Fanuc Controller
    - Two set of Pump unit
    - Two set of Filter unit
    I had No Experience with this kind of machine before, need some advice here:
    - What is the type / number of this machine?
    - Why do they have two kind of controller (Makino MGW-15 & Fanuc 200C)?
    - Where to find any documentation of them?
    - Possible to rebuild?
    - How about retrofitting (with mach3 for example)? They have Fanuc DC Servo Motor on the main unit.
    TIA, Ichan.
    Attached Thumbnails Attached Thumbnails MakinoMainUnit.JPG   MakinoController.JPG   FanucController.JPG   FanucDcServo.JPG
  1. junk box precision mill
    By KTP in forum Benchtop Machines
    Last Post: 04-29-2008, 02:25 AM
  2. Journeyman 320- convert or junk it?
    By Tom Curran in forum Tree
    Last Post: 12-11-2007, 06:55 PM
  3. Junk foam CNC?
    By ls7corvete in forum DIY CNC Router Table Machines
    Last Post: 03-15-2007, 04:29 PM
  4. Junk Physics
    By flakker in forum Benchtop Machines
    Last Post: 10-21-2006, 12:43 PM
  5. Help to identify another piece o junk again.
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 09-25-2004, 06:12 PM
