587,372 active members*
3,563 visitors online*
Page 1 of 7 123
Results 1 to 20 of 123
    Mar 2006
    304
    Talking My X3 CNC Conversion
    Just thought I'd share with everyone my X3 conversion. All the information gained from the fine folks here and on the EMC2 mailing list went into this puppy. Gallery Here
    It's still a work in progress and I plan to post detailed drawings and models so that others can emulate if they choose.
    Simply put it's 300 in/oz steppers on the X and Y direct drive, 600 in/oz on the Z at 2.6:1 ratio via timing belt. All the screws are Nook 0631-0200 XPR precision rolled with SRT nuts (5 tpi screws). Double nut on the X with compression preload instead of tension, single oversized ball preload on the Y, and just the single unmodified nut on the Z. All screws are secured in VXB angluar contact bearings - I couldn't justify the expensive stuff from the big names.
    I'm driving the G203V's @ 53VDC from a toroid transformer. The PC is a curbside find - an old Gateway P3 650MHz with 384mb of memory. It's not much but it's enough to run and get the job done. Complex jobs take a while to parse, but run fine.
    I moved all the electronics from the X3 column out of the column and into my driver enclosure. No reaching past the column anymore. Hope you all enjoy. Any questions - fire away.
    Every day is a learning process, whether you remember yesterday or not is the hard part.
    www.distinctperspectives.com
    May 2007
    715
    That is very impressive Cadmonkey. You have provided lots of good quality photos of your build as well. Thanks
    What size Controller box is that you have on the wall? I haven't been able to find one anywhere near that size for my components. Where did you order/find it?
    Mar 2006
    304
    30x30x8 - Overkill but for the price I couldn't pass it up. Lots of room for future expansion (As I do the Mr. Burns evil genius finger thing and say excellent...) I got it from a local R&D firm that was pitching it because it had a 2" knockout already punched top and bottom and they needed completely sealed units on the top to meet CE requirements. You can't even touch one of these for under $300 and I got it for nothing. A little silicone and a knockout plug and it's good enough for me
    Thanks for the compliment. As I find time I'm going to document the mechanical conversion step by step - it really wasn't as hard as I imagined it might be.
    Mar 2006
    304
    I just added another batch of pictures to the album - I noticed there were parts that weren't in the gallery and I didn't have any of the screw grinding pics.
    Mar 2006
    304
    The X3 is singing nicely. With the gibs polished up the X and Y are nice and smooth and I haven't lost a step and right now I'm pushing 30 IPS .001 DOC engraving the Redwings logo in a piece of 6061-T6511 on a .0625" bit - not a lot of cutter forces but going to a final depth of .030" in .001 increments (tonight is the 3rd night) is working nicely. If it weren't smooth and didn't hold position I'd have broken cutters. With the 2.6:1 ratio on the Z screw the head doesn't drop at all over 18 hours and can handle the TIGHT gib setting - it doesn't even shimmy as it moves at rapids (max speed is limited to 30 IPM on Z) - that gib and dovetail still need to be polished but I'll save that for when I install the limits and have to disassemble things again. I have the X and Y limited to 60 ipm right now but am going to test higher speeds later on and see if it can handle it. EMC2 nicely handles the small amount of backlash in my setup (Z is a lot of backlash but that's partly single nut and partly sticktion). All my circles are crispy. Once I get this bad boy done I'll polish it and post pics on my gallery.
    I'm so glad I "rolled my own" on this - I learned so much and it's paying it's dividends already. Thanks to everyone here I'm now staying up till 2 in the morning to let a program run...
    Greg
    Jun 2007
    7
    cadmonkey-
    Looks great, this is exactly what I hope to do with my X3 once I scrape together all the components ($$$). I saw in your gallery that you commented you may share your 2d prints of all the components you built for the conversion.
    I am a design engineer for a living, and I realize how much effort goes into detailing drawings. I would be very grateful if you would be willing to share that print pack- it would save me a lot of time when I get down to it.
    I understand if you aren't interested in making them public, but if you are, please drop me a line. Again, great job.
    Jason
    Mar 2006
    304
    They WILL be made public - that was my intent from the start. I garned so much information for free on the web I won't hold this back and try and make a profit off them. If I do try for a profit it would be making conversion packs to sell but I haven't made a call on that yet. Now that the machine is CNC they'd be very easy to slap together, but the screws are time consuming. Do enough though and I could upgrade my lathe and be able to go quicker...(sound effects from the Bionic Man echoing in my head...)
    The delay will be going back into the models and updating changes made at production time and corrections that I had to make (missing dimensions, hole callouts, that kind of stuff) and an accurate bill of materials. I hope to clean it up by mid July. I'm on vacation right after the 4th and have the cottage to myself so that's my goal is to work on those during the evening hours.
    I will state however - I am not, nor do I pretend to be an engineer. I did have a mechanical engineer look over things and make some recommendations of changes as I was designing but I won't guarantee anything.
    Thanks for the compliments.
    Mar 2008
    3655
    Good Job CM! I look forward to the updated plans.
    CR.
    Feb 2008
    81
    Looks like a lot of people have gotten the same ideas on retrofitting a better cnc conversion for these X3's at the same time. Your design looks surprising similar to my design as far as the Y-axis goes, except my steppers mount on top and is chain driven so the stepper doesn't stick out so far.
    My X mounts are similar to my Y mount. Once I get my production capabilities up to speed, I will be selling mine as a kit that will increase the Y travel to 8'' and X travel to and astounding 30''.
    I guess I should also tell you that I applied for my provisional patent a couple of weeks ago. Like you, I wouldn't have done that except for the fact that I'm disabled and can't get a job, so I'm going to have to make my own work. It's just a mater of economical survival you know. I'm all for you posting your designs on the net for people who are capable to manufacture their own to do so; I think it's a great idea. But If I can corner the market on selling mounts that let the ball nut move into the stepper mount, then I hope you understand that it's nothing personal.
    Here are some pics of the X and Y base mount so you can see what I’m talking about.
    Attachment 61538 Attachment 61539
    Mar 2006
    304
    Interesting! I knew my Y was going to be that way - I never considered doing the same theory with the X. Good thought - and patent away. My goal is in areas other than this so I don't plan to sell parts for conversions, it just popped out there I guess. The difference of my Y from what you've got posted is it's a 3 part piece so there's less stock to remove. Still, it had to be as thick as the mounting ear for the top and sides. The Y barely moves the nut into the standoff, I forget how many inches I get on the Y. X is just 2 or 3" more than stock.
    Good luck!
    Greg Michalski
    Feb 2008
    81
    Quote Originally Posted by cadmonkey View Post
    Good luck!
    Greg Michalski
    I have to hand it to you Cadmonkey; you’re a smart guy. I'm sure your other ideas are great, and you will have no trouble achieving you next goal. I've been casting parts to get around cutting it into multiple peaces. Solid cast parts will make for a fast and strong product.
    Mar 2008
    3655
    Quote Originally Posted by MetalBlade View Post
    ....that will increase the Y travel to 8'' and X travel to and astounding 30''.
    Hi MetalBlade. Welcome to the Zone!
    OK, I'll bite. How do you get 30 inches of travel with a 21" table?
    CR.
    Feb 2008
    81
    Well Crevice Reamer, the table is just barely short of 22 inches and each side of my mounts for the x-axis lets the ball nut mount move four inches past the table ends. Whether someone would want to push it that far is up to them. I'll probably recommend that they not exceed 28 but it will be up to them.
    Mar 2008
    3655
    Oh! I see. You are hyper extending the table off the dovetails. But the ACTUAL table travel relative to the spindle, (which is the way you measure table travel) then is about 20 inches. Well Done! What about the Z Axis?
    CR.
    Feb 2008
    81
    I'll probably add some warnings to not exceed a certain weight in order to cover myself in case someone’s table guides happen to break. I also might add dove tells to the final product or as you said table extensions. The z-axis is not changed other than the motor is mounted in the front that way wheel cranks can be attached for manual operation too.
    Mar 2006
    304
    Definitely add the warnings - your weak point is the base casting dovetails for the saddle Y axis - those are thin. The casting of the saddle for the table itself are pretty robust so those won't fail, but you could cantilever quite a bit of force on the thin dovetails of the base.
    Feb 2008
    81
    I've looked extensively over all the designs people have made for their Z-axis on the net, and haven't found anyone who has made a front mount for their Z-axis motor. Does anyone here know of anyone who has made a mount that looks like the one below that has public record of it prier to me positing this?
    Attachment 61633
    Feb 2008
    81
    The first prototypes of my designs were made out of wood and are rather ugly, but of course that’s not a big deal because they were never meant to be permanent. My new parts are aluminum cast in metal molds. I'm still trying to perfect the casting process, as you can see. This will probably be the last post I'll through up here in regards to my work, or at least until I have my website up and running.
    Thanks for looking
    Attachment 61643
    Mar 2006
    304
    I haven't seen anything like your Z mount - most everything I've seen for Z are either quill feed or rear/top mount steppers on the back screw. The gears in the back are tough to get good mesh for minimal lash.
    Adding to my earlier remark about the dovetail on the base being the weak point for cantilevered loads - looking closely at my saddle tonight - it's about the same thickness at the web for the table too, but in my conversion I noticed how much easier the base is to drill & tap compared to the saddle.
    Good luck on your venture - glad to see someone looking to offer something - more market competition is better for everyone.
    Mar 2006
    304
    Exclamation UPDATE!!!!
    I FINALLY got my print set completed. I am sure I missed something because I wasn't able to print off the last 2 revisions as I was making markups so please if you catch anything let me know either here or via the email addresses noted in the document. Eventually I will make the Solid Models available - for the moment its a waiting list kinda thing - I need to verify that the borrowed license for Solid Works I've been utilizing (brother has licenses available to check out from his office and checks me one out as he can but I don't know if I am legit to share those files since I personally don't own the license.) I couldn't have done this project without Solid Works as compared to Autocad (at least the Architectural version - Inventor may have been better and there are tons of software packages but Solid Works was really easy to learn and generate print sets and shop ready files (albeit I'd love to have G-Code generation from within SW instead of the dwf output and then cam-bamming it. Another great product - and very affordable!
    Ok - here's what you're all waiting for (drumroll please....)
    Cadmonkey's X3 Conversion Documents
    It's a simple PDF file and in short order I can provide stripped .dwf drawings to allow those that have access to CNC setups can run them through cambam or something else and speed up your conversions. I've got one person already lined up who has asked me to make his screws for him but as I stated earlier I am not getting into kits - I've got other interests and the possiblity of violating MetalBlades provisional patents leaves me wanting to stear clear.
    Take some time to review and let me know what you think - I will admit I am not a mechanical draftsman - I do architectural drafting for a living (along with IT and graphics arts and multimedia, etc.) so there may be some uncommon notation and over notation, unconventional scales, etc. I apologize, but - you get what you pay for - just remember that
    A word about the license mumbo jumbo - don't let it put you of - I'm just trying to make sure someone doesn't start using my plans to do production runs of the parts and selling kits, I really want this to be open source and free for all. The design was a learning experience and the production a whole separate one. Two things I would not pass up on, but I understand the design of something as complex as a 3 axis motion system can be a tad bit daunting - but the production is really simple in comparison - if you can't pull off the production then you might want to reconsider your chosen hobby. Just a friendly word of advice.
    Also I am not an engineer though one (not an as of yet licensed PE) did look over the design and gave some pointers and gave an informal blessing. It works on my will and I've been pushing it fairly hard and it meets expectations. Now to find time to work up my designs for the other interests.
    Anyone who doesn't have their controller all setup give EMC2 a try - cheap, wide support network and people from hobbyists to pro shops using it and sharing their experiences and knowledge on the mailing lists. It's a robust bugger and doesn't require a $500 PC (seriously it's running mine on a curbside find).
    Enough rambling - go on and check 'em out!
    Enjoy!
Page 1 of 7 123
  1. Who can do CNC Conversion?
    By Tim Wiltse in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2012, 08:13 AM
  2. Another X2 CNC Conversion (yay!)
    By skmetal7 in forum Benchtop Machines
    Last Post: 02-01-2010, 09:47 PM
  3. X1 Cnc conversion
    By persistant in forum Benchtop Machines
    Last Post: 01-28-2008, 11:06 AM
  4. VFD conversion
    By drwc in forum Phase Converters
    Last Post: 05-16-2007, 03:07 AM
  5. CNC Conversion?
    By muleworks in forum Bridgeport / Hardinge Mills
    Last Post: 07-14-2005, 06:15 AM
