586,780 active members*
3,620 visitors online*
Results 1 to 8 of 8
    May 2006
    249
    Calculate "Steps Per" In Motor Tuning
    'Afternoon everyone,
    Looking for some help on motor tuning in Mach3. To provide some basic background, I am running a PMDX-122 breakout board, a Gecko G320 servo drive, and an IMService servo assembly on a Taig 2019CR.
    http://www.cadcamcadcam.com/index.as...PROD&ProdID=62
    Now, under "Setup", it reads:
    The precise pulley ratio is slightly larger than 2.8:1. Use 5647.0588 steps per rev in quadrature mode (4X), and 1411.7647 in slot mode (1X).
    I assume I am in quadrature mode, so I have 5647.0588 steps per rev. Now, on the Taig, they use 20 TPI leadscrews. If I multiply 20 TPI by the above mentioned steps per rev, I get 112941.176 steps per inch. Is that what should be entered in the Motor Tuning page in Mach3?
    Yes, that sounds correct.
    May 2006
    249
    Okay, great- That value sounded a big high so I wasn't sure. But thank you for the confirmation
    Apr 2007
    641
    Scott Nichols from MAch, give me the best solution:
    In the settings tab (in the dro) on top of the reset tab, is the "axis calibration Steps per unit" You only have to input the movement you want measure hou much did it move , tell to MAch and set it. One minute , no calculating... !
    Luis
    May 2006
    249
    Awesome, I'll give that a shot, too. Thanks! Although, I think the method we've done is a bit more scientific and (perhaps) more accurate.
    Quote Originally Posted by Burn View Post
    It's more likely less accurate, because it doesn't account for error in the leadscrew and other components. Doing the math gets you in the ballpark, but you need to take actual measurements to get real accuracy.
    May 2006
    249
    Aah- Now that I think about it, that makes sense. Any way you could walk me through how to do that method (measuring)? Seems like it's the absolute best way to go from what I've re-read now
    Apr 2007
    641
    I used a laser level (cross lines) and drew a line perfectly centered and ask mach to move 150mm , then Mach asked how much did it move. it was about 147.6mm, press ok and Mach asked " do you want Mach to set it?"
    After I checked for a 1800mm length part cut and it was exactly..!
    Luis
  1. How to calculate a 3.5" NPT
    By Loading in forum MetalWork Discussion
    Last Post: 04-27-2008, 08:06 PM
  2. Motor Tuning and motor "wake up" ...?
    By matt888 in forum Commercial CNC Wood Routers
    Last Post: 02-12-2008, 02:54 AM
  3. Calculating "steps per" in Mach3 with Gecko 203V
    By millman52 in forum Machines running Mach Software
    Last Post: 11-28-2007, 10:04 PM
  4. What causes "missed steps"?
    By watsonstudios in forum Stepper Motors / Drives
    Last Post: 04-21-2007, 01:43 PM
  5. Calculating "steps per unit" for rotary axis?
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2004, 10:31 PM
