587,345 active members*
3,654 visitors online*
Results 1 to 8 of 8
    Feb 2006
    1260
    Calculating "steps per" in Mach3 with Gecko 203V
    Trying to tune motors in Mach.
    I have CandCNC's PlazPak1A with G203V Gecko's
    200 steps/rev.
    I have 4:1 reductions.
    pinions move axis 2.355" / rev.
    I didn't know how the CandCNC kit was set up (microstepping) so I asked :
    --- In CandCNCSupport@***********.com, "millman_52" <millman_52@...>
    wrote:
    > For calculating steps for entry in "motor tuning" in Mach.
    > Is my Plaz Pak set up standard with no microstepping as supplied from
    > candcnc?
    We use Gecko drives exclusively. All Gecko steppers are X10
    microstepping for any calculation.
    so is the following correct?
    200 X 4 = 800
    800 X 10 = 8000
    1 / 2.355 = 0.4246.........
    8000 X .4246..... = 3397.03
    so I would plug in 3397 in : Confi / Motor Tuning / Steps Per
    If it works.....Don't fix it!
    35538
    Looks right.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2007
    22
    I also dont have a clue how to configure my motor ect ....
    I got a 1600 driver --- 200 step motors
    15 tooth timing pulley attached to the motor connected to a 45 tooth timing pulley (3 :1 reduction i guess). the 45 tooth is attached to a shaft which has a 32 tooth timing pulley on a belt with a 5mm pitch ..... i read the mach2 setup and it still aint making sence ..please help!
    Feb 2006
    1260
    Quote Originally Posted by amen23 View Post
    by 1600 driver do you mean you have a driver running in 1/16 microstepping mode?
    unfortunately your 32 tooth pulley driving your belt is just about going to cancel out your 3:1 reduction. If I am reading your post correctly 1 turn of your reduction shaft is going to move your axis 160MM. Is this corrcet?
    Once I am clear I can help you calculate your steps per. for Mach.
    Mar 2004
    761
    How I do it:
    Set a starting number in the units per value like 2000
    Clamp a digital caliper on to the axis and set to zero.
    Move the axis one inch and write down the results of the digital caliper movement. Let say it moved .950 .
    Take the programmed value and divide it by the actual movment value. Multiply that value times the units per value to get your new units per value.
    (1.000/.950) * 2000 = 2105.26
    (Programmed/Actual) * Old Units Per = New Unit Per
    No silly gear head math required. But, it's good to know the gear head math if you really want to learn
    Wayne Hill
    Feb 2006
    1260
    I agree Wayne. I took the time to make very precise calculations on the reductions, gear teeth etc. The reality was once I had my table moving, I still had to do exactly as you state. Take a precise measurment at the table & found that I was off still by several thousandths. Adjusted steps per till I had it dead on. Then I double checked over a long run on my X axis. Wrote in a 1 line Gcode to move the X 10' It moved 10' exactly. At least as good as one could measure with a tape rule.
    Jun 2007
    22
    Quote Originally Posted by millman52 View Post
    yes millman --you hit the nail on the head.....the smallest i could go on the belt was a 32 tooth -- i wanted smaller but i settled ....to sum up...
    1 revolution on the stepper motor should translate to 53.33mm
    (Permanent 1/8 microstepping on all 4 axis', that's 1600 steps per revolution-)
    53.33/1600 = 0.03331 ---- which is close enought for a wood working cnc.
    Ger1 sent me a private message last night explaining Mach 3 ---''set steps per unit '' on the settings tab .......learn something new every day --havent tried it yet but would like to back it up with some calculations!
    Jun 2007
    22
    Quote Originally Posted by WayneHill View Post
    cheers wayne and millman ---- see my last post
  1. DynaCNC 24"X36" and Mach3
    By wellbuiltcabs in forum DynaCNC
    Last Post: 12-31-2007, 09:52 PM
  2. What causes "missed steps"?
    By watsonstudios in forum Stepper Motors / Drives
    Last Post: 04-21-2007, 01:43 PM
  3. "BRAKE BOARD" NEW Design for MACH3
    By Chivo in forum CNC Machine Related Electronics
    Last Post: 04-08-2007, 06:01 PM
  4. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
  5. Calculating "steps per unit" for rotary axis?
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2004, 10:31 PM
