586,756 active members*
7,614 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Why does My dxf file export like this
Results 1 to 8 of 8
    Apr 2007
    230
    Sorry I dont have much experiance with this. Some strange lines going to the elipses.
    Attached Files Attached Files
    Oct 2006
    975
    Did you create toolpaths in the CAD because it almost looks like a path to each hole, except that not all of the holes have these lines coming from them. If you exported after doing the toolpaths these lines will probably be included in the drawing. And the fact that when the line is selected and deleted it deletes the hole also(when opened in Autocad) makes me think it is a toolpath. If it is toolpaths you can go back to the CAD and select the toolpaths and delete them and then export it, probably good idea to save the file without the toolpaths also. I opened the Dice.dxf in Partmaster and it will delete the lines without removing the holes and also does not remark that the selected item is toolpath, so not sure about the toolpath idea. Hope I am not wrong, but take a look.
    Wes
    Apr 2007
    230
    Hi wes > The dxf file are being exported as tool paths. Ill try creating contours and then exporting
    Apr 2007
    230
    dxf
    That got rid of the long lines but now all the full circles are cut in half.
    Apr 2007
    230
    And now the circles where removed and replaced with curves
    Apr 2007
    230
    dxf. export
    This is it all cleaned up in profile lab. Dolphin reads it but makes a mess when exporting
    Apr 2007
    230
    got it
    preferences/ curves/convert to curves on dxf export[ off ]
    Nov 2004
    320
    export to r12 dxf if you have that potion
    later .dxf formats cause problems
  1. How to export file to v-carve for newbie?
    By dsgnkrft in forum Rhino 3D
    Last Post: 11-21-2007, 03:25 AM
  2. dxf export
    By pminmo in forum CamBam
    Last Post: 10-07-2007, 10:58 AM
  3. How to export g-code
    By tazboi in forum Mastercam
    Last Post: 07-06-2006, 09:15 PM
  4. Rhino dxf export
    By Ursine in forum Rhino 3D
    Last Post: 04-25-2005, 04:57 PM
