586,551 active members*
3,269 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Best Way To Cut Rubber With Hand Power Tools
    Nov 2006
    21
    Question Best Way To Cut Rubber With Hand Power Tools
    I'm trying to find a different way to cut rubber boxes than our standard method. The wall thickness varies from a quarter of an inch to a half inch depending on box type. Currently we trace the outline of the cutout and then use drills and jigsaws. I want to try either a handheld router or spiral saw (Rotozip) fitted with either a router bushing or top bearing bit so as to follow templates. I'm leaning towards the Rotozip with a jigsaw handle fitted with either of the mentioned guide accessories.
    I've read some of the CNC posts on the subject but for the time being we're using handheld power tools. I think freezing the boxes is out as that would increase the production time. So this leave bit choice and spindle speed. A Rotozip 5/32 bit will cut the rubber but I've definitely had instances of smoking at the bit.
    any suggestions?
    thanks
    Feb 2008
    if you froze several at a time say overnight it shouldnt effect actual machine production time.
    a bath of co2 or liquid n would be fast.
    Jul 2005
    12177
    Are you using anything as a coolant or lubricant? Soapy water works quite well with rubber.
    I have not done a lot of machining on rubber but I did determine that a very sharp tool with a large top rake worked best. Maybe you could try the micrograin carbide endmills with a very high helix angle that are made for aluminum. They do have a very sharp edge and the helix angle effectively gives them a large top rake.
    I woul try running at a modest speed, 2000 to 4000 rpm and use a rich soap solution as a coolant.
  1. Hand Tool Price vs Quality -- Keep my Money for Larger Shop Tools?
    By thkoutsidthebox in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-11-2008, 01:13 PM
  2. Sponge Rubber and Diamond plate looking rubber?
    By DennisCNC in forum Community Club House
    Last Post: 06-01-2007, 06:15 PM
  3. Bending/Cutting With Hand Tools
    By cibressus in forum Bending, Forging, Extrusion...
    Last Post: 08-13-2006, 06:33 PM
  4. PWM control for cheap power-tools?
    By medved in forum CNC Machine Related Electronics
    Last Post: 10-10-2005, 03:11 PM
