586,619 active members*
2,491 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > 5-axis mill for cutting compound curve planks
Results 1 to 2 of 2
    Mar 2008
    1
    Hello all, I am working on a wooden boat project. The planks are quite unique in that they are cut from a solid tree trunk (typically two planks per 10 foot cedar trunk).
    Questions:
    1. Are there any suitable multi-axis mills that will cut a cedar log/tree trunk with compound curves?
    2. Is there a machine that will cut a log that is 10 feet long? The longest plank is 10 feet long, but others will be in the range of 6 to 8 feet.
    3. Do you know of any wood/furniture CNC houses that have 5-axis capability for stock of this size?
    This boat will be used on an expedition and building it using original methods (planks cut from solid trees) is a must. No steamed/clamped flat planks here. Compound curves are used throughout.
    Thanks in advance for your suggestions.
    Cheers,
    Sandman
    Apr 2007
    1955
    Hi Sandman - I sent a PM to you.
  1. installing compound angled holes on 3 axis machines
    By krustykrab in forum Hard / High Speed Machining
    Last Post: 10-14-2007, 02:46 AM
  2. Enco Compound Slide Milling & Compound Drilling Table
    By 7ofclubs in forum DIY CNC Router Table Machines
    Last Post: 12-24-2006, 05:43 AM
  3. What's the learning curve for the TL-2
    By rbest27 in forum Haas Mills
    Last Post: 12-18-2006, 05:29 PM
  4. compound angled holes on 3-axis machine
    By krustykrab in forum Uncategorised MetalWorking Machines
    Last Post: 05-17-2004, 05:49 PM
  5. Project a curve
    By keithorr in forum OneCNC
    Last Post: 04-03-2003, 05:36 AM
