586,808 active members*
7,998 visitors online*
    Jan 2007
    118
    Formatting-PCMCIA
    HELLO FRIENDS,
    IS IT NECESSARY TO FORMAT THE PCMCIA CARD IN THE FANUC CONTROL BEFORE TAKING SRAM BACKUP.
    2.IS IT SUFFICIENT IF WE TAKE ONLY SRAM BACKUP.
    THANKS,
    CHANDRU
    Sep 2007
    371
    Usually you do have to format the PCMCIA, you can do it on the control or in the PC directly, this must be done after you replace the battery, etc.
    I suggest you also backup the parameters and programs with the RS-232, this way you'll have and ASCII backup.
    GP.
  1. Broke a pin off in the PCMCIA port...
    By pdoherty in forum Daewoo/Doosan
    Last Post: 08-23-2007, 09:59 PM
  2. PCMCIA to DB9 to DB25
    By adda in forum Machines running Mach Software
    Last Post: 05-30-2007, 02:04 AM
  3. PCMCIA Card
    By bdwalker in forum Fanuc
    Last Post: 03-13-2006, 10:36 AM
