586,834 active members*
2,973 visitors online*
    Dec 2006
    242
    Can I adjust cutter comp diameter within a program?
    Hey guys,
    I've been running my CNC for nearly 10 years and I've always wondered about this? Can I cut a path, and then within that program reduce a tool's diameter offset a couple used in G41 by a couple thousandths and re-run the same path for a finish cut? If not, do you have any suggestions other than using a second tool as a finisher which would require a toolchange and really slow things down in production?
    Dave
    Jul 2005
    12177
    Yes just use the G10 command.
    G10 L12 G90 Pn Rn will put the diameter or radius Rn into the Tool Compensation Table for tool Pn.
    For exampl to set the tool 1 comp diameter to 0.500" using diameter measure the command is G10 L12 G90 P1 R0.5; if it was using radius measure you would use R0.25.
    This comp entry is called by G41 D01 and you can keep changing it through the program.
    I prefer to put everything at the top of the program and instead of changing the entry for the tool I use several entries; this works on Haas but it may not on other machines. I would have:
    G10 L12 G90 P1 R.5
    G10 L12 G90 P21 R.51
    G10 L12 G90 P31 R.75
    Then for doing a profile or something I would make a roughing pass using G41 D31; then follow the same path using G41 D21 and finish with the G41 D01. Between each pass there is a tool compensation cancel (G40) back to the starting point.
    This way you are not fiddling with values in the body of the program and you can tweak the final size by using the wear for tool 1.
    One thing to watch with this technique is that if there are any concave (G03) curves in your profile the largest R value has to be small enough to fit inside these curves. That, or you have two sets of coordinates with the curves taken out of the roughing set.
    May 2007
    781
    What I do is declare one of the tool offsets for temp use only, the highest number is the most logical. Then in the program I copy the offset from the one the operator is setting to the temp one, adding whatever extra I want to leave for the finish pass.
    Rather then using G10 I normaly just dig thru the manual and find out what system variables the offsets are stored in.
    This would take tool offset 1 add 0.010 and put it in offset 20. Offset 20 would then be used in the tool path.
    #13020=#[13000+1]+0.010
    The base number (13000) of the offset table depends on the control and what type offsets are being used. Which is why G10 is often used.
  1. Cutter Comp?
    By donl517 in forum Fadal
    Last Post: 07-03-2007, 02:36 PM
  2. cutter comp in eia
    By mrwright in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-21-2007, 01:53 PM
  3. 18-it cutter comp
    By newcinhypro in forum Fanuc
    Last Post: 01-26-2006, 03:00 AM
  4. G-Code Cutter Comp Program
    By jcc3inc in forum DIY CNC Router Table Machines
    Last Post: 02-27-2004, 05:29 PM
  5. Not using cutter comp
    By HuFlungDung in forum OneCNC
    Last Post: 05-28-2003, 10:59 AM
