587,923 active members*
3,375 visitors online*
Thread: Cutter Comp?
Results 1 to 6 of 6
    Oct 2006
    143
    Cutter Comp?
    Can cutter comp on the CNC88 be turned on with a G2/G3 as opposed to a G1?
    Thanks,
    Don
    Feb 2007
    36
    i don't see why not. so long as you have a "fake move" first before you hit material. usually i use a g1 as my "fake move" then a g2/g3.
    Feb 2006
    992
    I doubt it...... check your manual. From what I remembered machine only turn on cutter comp with G00 or G01 anything else will be alarm.
    The best way to learn is trial error.
    Jul 2004
    374
    yes, you can turn cutter comp on or off with a G2/G3
    I stopped doing this because of program compatibility issues with out other machines, that will not allow this.
    Apr 2007
    21
    Smile
    +2, you can use G2/G3 for CRC. on the HS88
    900
    Although the control will accept the G41/G42 code on a G2/G3 move, this is considered a VERY poor programming practice. CRC tells the control to place the tool tangent to the next entity. It can be very difficult sometimes to predict where that tangency point will be and therefore can subject the part to unwanted gouges.
    Neal
  1. cutter comp in eia
    By mrwright in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-21-2007, 01:53 PM
  2. Cutter Comp.
    By Big"E" in forum MetalWork Discussion
    Last Post: 03-28-2007, 05:05 PM
  3. FeatureCam cutter comp
    By Jim Bass in forum FeatureCAM CAD/CAM
    Last Post: 03-28-2006, 02:49 PM
  4. 18-it cutter comp
    By newcinhypro in forum Fanuc
    Last Post: 01-26-2006, 03:00 AM
  5. Not using cutter comp
    By HuFlungDung in forum OneCNC
    Last Post: 05-28-2003, 10:59 AM
