586,698 active members*
2,985 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > GRBLGRU INCH G CODE AND G02/G03
    Jun 2023
    9
    Cool GRBLGRU INCH G CODE AND G02/G03
    Hello, I'm new here. My question:
    1, Is it possible to output Inch G code with GRBLGRU?
    2, Can GRBLGRU output G02 and G03 ?
    Thank you
    Regards
    Mel R
    May 2016
    334
    Re: GRBLGRU INCH G CODE AND G02/G03
    To 1.
    The GCode calculated by GrblGru in the automatic mode is always generated in metric format. However, with the macros you can also program GCode in imperial format. I don't know your use case, but maybe the macros can help you with that.
    Have a look at the video below.
    Re 2.
    GrblGru can also generate G2/G3 commands. However, this is only done in individual cases, because with projections or when using 4/5 axis, circles quickly become ellipses, which can no longer be mapped in this way. Today, current controllers can also quickly process polygonal traverses.
    Here again the reference to the macros. Of course you can use G2/G3 command.
    https://www.youtube.com/watch?v=AwdbhN32g-4
    Jun 2023
    9
    Thank you. This helps. I can convert G code text from metric to inches after posting out but needed to ask if it could output directly.
    1230
    Wouldn't a G20 or G21 in the program header deal with this?
    May 2016
    334
    If your controller understands the commands this will of course work. But I assumed that melrod has a controller that can't do that.
  1. G02 G03 reversal
    By dek in forum Fagor Automation
    Last Post: 07-24-2010, 01:01 PM
  2. G02 and G03
    By Spunk in forum LinuxCNC (formerly EMC2)
    Last Post: 01-15-2009, 08:48 PM
  3. G02, G03 Feedrate !!!!!
    By usb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-16-2008, 01:19 AM
  4. g02 g03 explanation
    By valmet58 in forum Community Club House
    Last Post: 03-20-2008, 03:36 AM
  5. Problems With G02 G03 Using I And J
    By Jim Estes in forum BobCad-Cam
    Last Post: 12-19-2005, 02:22 PM
