587,354 active members*
3,493 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Bypass/Disable ATC on a Okuma MX 45 VAE/OSP 700M
Results 1 to 20 of 25
    Mar 2015
    21
    Hi CNC Brothers and Sisters,
    I have an older Okuma that runs 1 operation production. The driver board for the ATC is on it's 3rd replacement after biting the dust. There is not an ATC on the machine but we still use it for single operations. I'm an looking for a way to bypass/Disable the ATC so the alarm goes away. I contacted Okuma tech support and being the machine is older there isn't anyone that would know how to go about doing this. I haven't found any options in the manual nor the parameters list.
    Please if anyone reading this knows how to fix this I would be truly grateful.
    I would also pay $$$ to get this fixed.
    Thanks in advanced,
    David Oates
    Dec 2008
    3124
    Re: Bypass/Disable ATC on a Okuma MX 45 VAE/OSP 700M
    Replace any & ALL M6 commands in your NC code with M0 (program stop)
    Jun 2015
    4156
    oau, nice, pretty good superman
    that's a good point, i wonder why else would there be atc related errors, if machine does only 1 operation ? you are the ( sup er ) m a n
    Dec 2008
    3124
    Quote Originally Posted by deadlykitten View Post
    Kitty... read his post
    He is "pissed" that too many usless toolchanges have possibly stuffed his driver boards
    PLUS...
    HIS F#$%N MAGAZINE HAS DECIDED TO GO ON HOLIDAYS.
    That model came out as OSP7000M, you may find the screen came from an OSP700 machine ( or its a typo?)
    Mar 2015
    21
    The ATC is no longer on the machine unfortunately. Having to buy these driver boards just so the machine can operate does suck.
    So to wrap it up...I don't have a ATC but when the driver board goes I still have to buy another one. Go figure.
    Jun 2015
    4156
    worth trying, but unfortunately i can't do it for 700M :
    ... plc scaning with & without that board then manage the difference by forcing a signal
    ... disable special function
    for replacements/service, try okumaelectronics.com / kindly
    ps : superman, i really thought that M6/M0 would be a nice quick fix
    Dec 2008
    3124
    Tampa, you would also have to comment any T# as well, as this would try to force motion to the tool magazine (either to toolchange or prepare next tool).
    Any M63 must also disappear ( readies an empty pot for emptying the spindle.
    ie.
    M0 ( T# M6 )
    or
    ( M63 )
    Mar 2015
    21
    Unfortunately I can write programs all day and it still will not get past the alarm. Hence trying to bypass the ATC alarm caused by the driver board.
    Also, The ATC is no longer on the machine. :tired:
    Quote Originally Posted by Superman View Post
    ie.
    M0 ( T# M6 )
    or
    ( M63 )
    Dec 2008
    3124
    Quote Originally Posted by TampaCNC View Post
    I understand your issue from the 1st post.
    I'm saying you need to eliminate any code that tries to make the magazine come into play ie. the M6, T#, M63 and I think M64
    What is the actual error that appears ( entire 2 lines) ?
    Mar 2015
    21
    SVP Error with the driver board. Common problem with this particular. Plus there has been no need for adding M6, M63, or M64 in my programming since the machine is just 1 operation.
    Thank you for the idea you had though.
    I was just hoping my resolve wouldn't be a costly $$$ one.
    Nov 2007
    364
    You would be looking for a Parameter -Long or Short that can tell the machine ATC not active ------------On Fanuc its a Keep Relay and Most Okumas used to have this option
    Oct 2009
    119
    Ask to Okuma sevice to change ATC spec code.from software.
    15362
    ie.
    M0 ( T# M6 )
    or
    ( M63 )
    He has an Electrical / Electronic problem not a code problem, no amount of coding is going to solve this problem, he would have to change it in the machine logic to eliminate the Tool change operation
    Mactec54
    Apr 2009
    1262
    It appears that you may be able to "shut it off" by changing the spec code in a few places:
    EC spec code:
    With ATC =0
    With TS axis =0
    Without TS-axis drive motor =1
    They should be in the spec code file...this is something Okuma normally changes...and still should be able to in spite of what your distributor says.
    Kurmay claims to be able to do this. My success has only left me with a "test software" message, but may be able to prove this theory - because I have not tried doing this mind you. Only theory based on experience. The message would be better than the alarm IMHO.
    Right now the machine is probably looking for the motors and encoders and will always be until the software spec code is changed.
    Best regards,
    Experience is what you get just after you needed it.
    Jun 2015
    4156
    Hy mr wizard if i may, what have you done so to get that message poped out ?
    if spec involves hardware, then is not as easy to diagnose the effect of spec on/off; only method is to hope to achieve longer life than what the previous 3 boards delivered, but longer life may not be caused by spec ... i wonder what lifetime was there for previous boards
    another idea is to compare plc map with and without the board, then mask the difference
    Or simply rely on service technician to diagnose a failed board, or compare it to another in good condition, so to localize the deffect / kindly
    Jun 2015
    4156
    spec off + remove board ? i would try it
    Oct 2009
    119
    Yes board and motor
    Mar 2015
    21
    How do I achieve turning off the spec? :stickpoke
    Jun 2015
    4156
    as 1st recomandation, talk to kurmay
    Jan 2013
    474
    Are we talking about an axis servo control board or the NC control driver ?
  1. Replies: 2
    Last Post: 09-23-2019, 01:37 AM
  2. OKUMA OSP 700M Error code 5427
    By joacom in forum Okuma
    Last Post: 06-25-2019, 07:20 AM
  3. Okuma OSP 700M/7000M RS-232 parameters
    By sld4121 in forum Uncategorised MetalWorking Machines
    Last Post: 05-01-2013, 06:33 PM
  4. okuma osp 700m
    By bennyboy78 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-14-2011, 02:07 PM
  5. Okuma Osp-700m Dnc Parameters !!!
    By miguisu in forum DNC Problems and Solutions
    Last Post: 05-16-2007, 04:13 PM
