586,762 active members*
7,437 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Frenic 5000 M3 digital AC spindle drive...,
    Dec 2005
    55
    Question Frenic 5000 M3 digital AC spindle drive...,
    Hey Guys,
    I have A Nakamura Tome TMC 15 that has an indexing spindle. It is a Frenic 5000 M3 digital AC spndle drive. The spindle has a gear on it that enables you to rotate and lock in at every 7.5°. There is also adjustment on the locking dog so you can orientate it within that 7.5°. The problem is that when the adjustment is near the limits, sometimes the dog hits the very top of the gear and the machin hangs waiting for the lock signal from the prox on the dog. If I could adjust the orientation of the drive, I think I could solve this problem as you can see the spindle 'jump' back when it locks in.
    I have the drive book in front of me but I can't make sense of it. There are two settings which are C007 - Stop position setting value, and P30c - Orientation internal position setting. Both require a hexidecimal value. Can some one explain how to do this?
    I'll attach the Function table for your viewing pleasure.
    Thanks Guys,
    Jon K
    Attached Files Attached Files
    Mar 2012
    I have been searching all over for a drive manual and can't seem to find one. Do you have the pdf manual? If so could you email it to me? I too am working on a Nakamura Tome but a TM-10.
    good day.
    I have the same drive and I have a problem with the signals of CN1. Your Connection have the manual for this drive?. I would greatly appreciate if you could help me solve this problem. Thank you.
  1. Fuji frenic v5000 spindle drive problem
    By zoeper in forum CNC Machine Related Electronics
    Last Post: 08-04-2013, 08:32 AM
  2. Fuji Frenic 5000
    By hotrob1 in forum CNC Machine Related Electronics
    Last Post: 02-03-2010, 08:20 PM
  3. Fuji Frenic Spindle Drive....repair options
    By TR MFG in forum CNC Machine Related Electronics
    Last Post: 09-16-2008, 12:29 AM
  4. Fuji Frenic 5000 V2
    By shuggie in forum Servo Motors / Drives
    Last Post: 05-14-2008, 05:51 AM
  5. Digital Spindle Drive
    By Jagermeister in forum Uncategorised MetalWorking Machines
    Last Post: 11-14-2006, 01:52 AM
