587,729 active members*
3,383 visitors online*
Results 1 to 6 of 6
    Mar 2007
    76
    Question Fuji Frenic 5000
    I'm in need of a 'hybrid module' marked BASELOG TM 3201 on it. It is out of a Fuji drive. The module is on the main board and the numbers off the board are EP 2248C and also has HAH30798 on it.
    Does anyone have or know of a scrapped board or unit? I'll take something that is close. Could use this information rikki tick.
    Re: Fuji Frenic 5000V (FSD 7AR-22)
    Thanks.
    -HOTROB1-
    Mar 2007
    76
    Unhappy Fuji? Anybody?
    Surely someone knows of a scrapped board or Fuji unit. I'll take something close. Trying to get this one repaired. The problem is the hybrid module on the main board. I'll take a main board if there is one available. Any help would be appreciated.
    T.I.A.
    Mar 2007
    76
    Exclamation Any help?
    No one out there with any help or suggestions???
    Thanks.
    Oct 2006
    100
    Did you find the Hybrid ?
    May 2009
    9
    FUJI no longer supports Fuji Frenic 5000V. As far as I know the only drives supported are FUJI FRENIC Mini, Eco, 5000G11S, 5000P11S, 5000VG7S & Multi series.
    http://www.ctiautomation.net/FUJI-Inverters.htm
    Feb 2010
    0
    need help, have frenic 5000 g11s drive unit am unable to access progam and only recieve ER1 on the display unit any suggestions
  1. Fuji frenic v5000 spindle drive problem
    By zoeper in forum CNC Machine Related Electronics
    Last Post: 08-04-2013, 08:32 AM
  2. Fuji Inverter problem
    By flinty in forum DNC Problems and Solutions
    Last Post: 03-09-2012, 10:23 PM
  3. Fuji Spindle
    By wanchai101 in forum Fanuc
    Last Post: 07-12-2006, 10:28 AM
  4. Fuji Spindle Drive.
    By cncdiag in forum Fanuc
    Last Post: 06-20-2006, 03:59 PM
