586,635 active members*
3,390 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > New huanyang VFD and spindle error EoAA
Results 1 to 20 of 27
    Mar 2022
    9
    Greetings brand spanking new here hoping you guys might be able to help me out. I set up a new vfd and spindle using Mactec54's settings below:
    Huanyang 110v 2.2Kw vfd huanyang 110v 2.2Kw WC spindle.
    After initial setup when I press run the spindle starts automatically and after a few seconds will display AoA then EoAA and stop.
    The spindle pin 4 is grounded and continuity tests positive between the pin and the body.
    I soldered the cable myself. It is a double shielded 16/4 wire and I have a drain wire connected to the green ground in the 16/4. Continuity was tested end to end.
    Checked resistance on the spindle pins. Tested 0, 0, and .2
    I'm a bit at a loss and hoping the folks here might be able to point me in the right direction.
    My wiring is attached:
    Input power 110v wired to R T and Ground
    Spindle is UVW and has the 16/4 ground and drain wire connected to the same(only?) Ground as the input power.
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD011=120 (Minimum Setting 120)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Accel=12 ( Adjust to suit)
    PD015 Deccl=12 (Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage ) (120 for VFD Rated for 120v )
    PD142=9 ( Motor Max Amps) (Set for your motor Amp Rating 2.2Kw Spindle 9 amp Max)
    (Set for your motor Amp Rating 1.5Kw Spindle 7 amp Max)
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD002=1 ( For Remote Pot use )
    PD70=0
    PD72=400
    PD73=120
    15362
    Re: New huanyang VFD and spindle error EoAA
    Quote Originally Posted by OlmsteadWorkshop View Post
    Huanyang Mactec54
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD70=0
    PD72=400
    PD73=120
    The settings you are using is for a 220v spindle motor change this for a start, 2.2Kw spindles do not work well on 120v NA supply do you have a 30A supply
    PD008=110
    PD141=110
    EOAA is overload have exceeded 150% this could be the lack of enough input power / amps
    Mactec54
    15362
    I should have said also you can't use a drain wire or shield connected to Ground directly, this will and can cause problems, a Shield Drain wire should never be use for termination of a shield.
    Mactec54
    Mar 2022
    9
    Thanks Mactec54. I should note I do have those two values set to 110 not 220 for my supply. I'm a bit limited on power due to it being residential, but I will remove the drain wire that is connected to the ground a report back.
    15362
    20A will get it running 30A will be best, make sure you are using a switch to turn it on/off the supply power, if you just plug it in to an outlet you can damage the input to the VFD Drive
    Try this set of Parameters
    Huanyang Mactec54
    2.2Kw 110v 400Hz Water Cooled / Air Cooled
    PD000=0 ( 1 For Parameter Lock )
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
    PD003=400
    PD004=400
    PD005=400
    PD006=5
    PD007=20
    PD008=110 (Motor Rated Voltage )
    PD009=15
    PD010=15
    PD011=120 ( 100 Minimum Setting For Water Cooled Spindle )
    PD013= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=8 ( Adjust to suit)
    PD015 Deceleration=8 (Adjust to suit)
    PD023=0 ( Forward Run Only )
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD120=100 ( Stall Prevention )
    PD141=110 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
    PD144=3000 (Max Motor RPM) 3,000= (24,000)
    PD070=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD072=400
    PD073=120 ( 100 Minimum Setting Water Cooled Spindles )
    PD174=11 ( To Be Set to the VFD Drives Max Rated Output Amps )
    Mactec54
    15362
    Also set PD142=7 (this may help if the Power supply current is not enough)
    Mactec54
    Mar 2022
    9
    Thanks for all your help Mactec54. After tweaking the settings a bit and removing the grounded drain wire I'm nearly there. I can tell it wants to go. It spins about twice as long and begins ramping up before it stops and errors again. At this point it really seems power supply related. I did test on a 20amp. I've got a fuse panel with lots of space down in the barn so I'm going to try and get a 30amp circuit setting up for testing.
    Mar 2022
    22
    I can't speak to your device, but my VFD would throw an errors when my control signal was not what it should be (long story, won't go into it). I would either get an overcurrent constant speed or an overcurrent acceleration fault if the control signal was jumped at the terminals in a way that the VFD did not like. Granted, I have a different series VFD from Huanyang, but something to keep in mind.
    I would try to shut everything down, power back up, and the fault would still be there every time I would attempt to run up.
    I found that the VFD was retaining memory of this and not clearing it when I powered down.
    I also found that by powering down and letting the VFD sit in an unpowered state for about 10 minutes, the faults would clear and I would not have any issues running the spindle. I have repeated this procedure and it works. I am not sure if this would work on your HY series VFD, but powering down and letting it sit for about 10 minutes doesn't cost anything and is something you could try if the faults keep showing up.
    15362
    Ok increase PD014 and PD015 you can use any number try starting PD014=15
    Only increase PD015 if it faults on slow down
    Turn the Pot down to half you can check to see if this is working by disconnecting the spindle motor, and power up the VFD Drive and use the pot to run it up down the speed range if the pot is not working, I will help you with some parameters to get this working
    Mactec54
    15362
    Quote Originally Posted by Padawon01 View Post
    Sounds like you have messed up your wiring connections
    Mactec54
    Mar 2022
    22
    There is literally nothing to mess up.
    Ground
    R
    S
    U
    V
    W
    Motion control ground to terminal ground
    Motion control 0-10V to AI2 terminal
    S1-COM terminals jumped
    I'm not going to add any more comments about my VFD issues here. Just sharing a free troubleshooting step with the OP. My intent is not to muck up his thread.
    15362
    Ground
    R
    S
    U
    V
    W
    Your main Power Connections should be R and T plus Ground for single phase use, Not R and S for this VFD Drive, so this needs to be corrected
    What you messed up was the logic low voltage, when you did the relay connection.
    Mactec54
    Mar 2022
    22
    I was about to question the R & T vs the R & S for a 3-wire 240v hook up.
    The first VFD that I had (same model) would not respond to R & T. I contacted the manufacturer via skype and was told to use R & S - which worked perfectly fine.
    The VFD that I am using now - I never hooked up to R & T since the manufacturer said to use R & S, but after trying it, it works. So R & T it is.
    Nevertheless, I have about had it with this GT-series VFD and will be trying an HY in its place.
    Mar 2022
    9
    Still testing on a 20amp.
    When using the pot without the spindle connected ROTT will go from 7200-15952(flashing back and forth with 15969)
    With the spindle connected and the pot turned all the way down and PD014=15 it will spin up to ROTT 300 then shut off.
    15362
    [QUOTE=Padawon01;2500265]I was about to question the R & T vs the R & S for a 3-wire 240v hook up.
    That is total Bs the manufacture knows better than that. if this is the case, they have not indicated that they have changed the input which is possible, this would keep it the same as most other VFD Drive manufacturers, but I doubt that this has happened as I have the schematics for this drive and there is no change
    The GT is a much better VFD then the regular HY VFD Drive, the GT being a little more complicated to setup but quite straight forward if you can understand how they have done the manual
    Mactec54
    15362
    Does it give you a Fault when it shuts down??
    Ok the Pot needs some different Parameters set, this should give you the whole RPM range, try it again with the motor disconnected
    Mactec54
    Pot Control
    PD001=0
    PD002=1
    PD070=1
    JI Jumper 2-3 / VR Position
    I will give you some other parameters to try
    Can you do some close up photos of the wiring ???
    Mactec54
    15362
    Change these Parameters
    PD006-2.5
    PD007=.5
    PD009=15
    PD010=8
    Need to see a photo of all the wiring connections
    Mactec54
    Mar 2022
    9
    Mactec54
    Pot Control
    PD001=0
    PD002=1
    PD070=1
    Changed the above parameters and the below posts. I now get up to 23000 ROTT without the spindle connected. I'm not sure what the JI jumper is I may need to check the manual on that one.
    Same issue. Right around 300ROTT the spindle errors with EoAA
    Wiring is attached
    Live=R Neutral=T Ground=Ground. Pin1=V Pin2=W Pin3=I Ground=same ground as power in
    Attached Thumbnails Attached Thumbnails 16475721797705167834058500778892.jpg
    15362
    Wiring is attached
    The J1 jumper is beside the logic terminal block to the right, some times this is already in the right position but you can try it in both positions to see which works the best.
    Pin numbers should be.
    Pin 1=U
    Pin 2=V
    Pin 3=W
    Pin 4=Ground
    So, this needs to be corrected
    Mactec54
    15362
    I hope this was a typo Pin3=I not sure what you were meaning by this connection
    This is why Photos are important, when trying to see where there are problems
    Mactec54
