Does it give you a Fault when it shuts down??
Ok the Pot needs some different Parameters set, this should give you the whole RPM range, try it again with the motor disconnected
Mactec54
Pot Control
PD001=0
PD002=1
PD070=1
JI Jumper 2-3 / VR Position
I will give you some other parameters to try
Can you do some close up photos of the wiring ???
Mactec54
Changed the above parameters and the below posts. I now get up to 23000 ROTT without the spindle connected. I'm not sure what the JI jumper is I may need to check the manual on that one.
Same issue. Right around 300ROTT the spindle errors with EoAA
Wiring is attached
Live=R Neutral=T Ground=Ground. Pin1=V Pin2=W Pin3=I Ground=same ground as power in
The J1 jumper is beside the logic terminal block to the right, some times this is already in the right position but you can try it in both positions to see which works the best.
Pin numbers should be.
Pin 1=U
Pin 2=V
Pin 3=W
Pin 4=Ground
So, this needs to be corrected
Mactec54
