586,619 active members*
2,460 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Sheet Metal Miter Not Good Need Help...
    Jun 2006
    42
    Hi everyone!
    I am bending 1/4" aluminum plate, and it needs a pretty good bend radi of .5" here is a pic of my problem, it unfolds ok but the miters are not the best, any ideas of how to make it better? Its the large cut out that is somewhat triangular is this normal?? -Thanks
    http://www.dreamtone.org/cnc/Mechanical_Design.JPG
    Jul 2003
    1220
    I would think you need a round hole punched/drilled to cut the shape for your corner while on the flat.
    Sep 2005
    1660
    It's called a relief, if you had mat'l in that area from both sides it wouldn't form correctly. The relief's are customizable for size as well as shape..
    JerryFlyGuy
    The more I know... the more I realize I don't
    Jun 2006
    42
    Quote Originally Posted by JerryFlyGuy View Post
    Right; I was wondering about that, but do you know where to find that info for the relief size and shape? I tried looking and I thought I tried everything. The only thing that came close was to the "close corner" icon BUT it only worked on a "flange" not the "mitered flange" and that is what I have here.
    Sep 2005
    1660
    go to "Sheet Metal" in the feature tree , right click and edit feature.. the relief stuff is in there.. if you need to just read up on it in the help menu.. suprisingly.. the help files in SW are pretty helpful [contrary to most Winblows programs..]
    You probably want an obround or tear relief instead of sqr.
    JerryFlyGuy
    Jan 2004
    3154
    It is also very easy to "collect the bends", unfold the part and sketch in your own custom relief in whatever shape you want.
    As Jerry said, the relief is defined in the bend feature.
    www.integratedmechanical.ca
  1. Sheet Metal Patterns
    By phatfred8 in forum Solidworks
    Last Post: 05-21-2009, 08:34 PM
  2. Bit recommendation for sheet metal
    By adda in forum Uncategorised MetalWorking Machines
    Last Post: 01-26-2007, 08:50 PM
  3. Tog Gun Construction From Sheet Metal
    By username132 in forum European Club House
    Last Post: 01-15-2007, 02:11 PM
  4. cheap sheet metal
    By MBG in forum MetalWork Discussion
    Last Post: 03-04-2005, 07:35 PM
  5. Thin sheet metal
    By itsme in forum Welding Brazing Soldering Sealing
    Last Post: 03-01-2005, 10:24 PM
