I think you can get insert bends to work, but.. and its a big but.. you'll have to take the profiles and add a straight segment into them. This segment will then need a fillet into the curved profile. If you taper the straight segment proportionally from top to bottom and then loft it "thin" [ or w/ a full drawn profile.. either will work] you should be able to click on the straight/flat segment of the cone and "insert bends".. its a work around... i've never had to use it but.. its possible..
It's been a few years since I drove 2000.
Jerry [learning something new everyday..]
JerryFlyGuy
The more I know... the more I realize I don't
