587,517 active members*
3,521 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 1010 Axis cards and blue dummy plugs
Results 1 to 9 of 9
    Nov 2010
    8
    Hi!
    I have several basket case fadals im working on and I have question about 1010 axis cards.
    Attachment 465680
    What are these plugs and why some cards (X, Y, Z) have them and some don't? Also sometimes the plug is in "Encoder" connector and other times it is in the "Scale" connector. Some of them seem to have hand written X, Y or Z on them.
    Nov 2012
    1272
    Re: 1010 Axis cards and blue dummy plugs
    Looks to me like a spare empty ribbon connector. Some prehistoric engineer might have used those dummy connectors to label the cards as X, Y or Z as he swapped them. Just a guess.
    Aug 2009
    1573
    ...I am thinking you already know this but, just in case you do not know the Config of the Jumpers on this DIP Socket is how to set card and of coarse the eprom's must match.
    Nov 2010
    8
    Yes i do.
    I managed to get one machine running allthough there is weird issue.
    I performed full calibration to the axis drive system starting from feed clock test.
    I cant seem to set the X-axis following error to +- 595. The potentiometer runs out of travel at +-540.
    Y and Z are fine.
    Aug 2009
    1573
    ... Is your incoming 3 phase power(voltage across lines) low ?..... easy to adjust with the Transformer taps or maybe the 5% Low parameter
    Nov 2010
    8
    Quote Originally Posted by machinehop5 View Post
    I have not touched the wiring, it came from 3x400V shop and my shop is 3x400V as well.
    Servo amp big blue capacitor measured 168 VDC while all 3 axes were moving.
    Aug 2009
    1573
    ...its easy to check wiring/jumpers to Transformer. Spindle drive also. The number one killer of spindle drives is over voltage. So, worth getting it correct. ASSUME NOTHING is set correctly and double check. If, the Chart inside the door is missing here is the manual with want ever model Transformer you have. The T-818 probably
    Nov 2010
    8
    Thanks!
    I will take a closer look next week. Other than not being able to set the servo following error to factory specification the machine seems to be running well.
    Actually I am fairly surprised how well the machine is running right now, it came to me as pile of scrap parts. So far only thing I had to purchase new was one resolver for X-Axis. I was able to salvage other parts and get the machine going to a point where it runs G-code from computer.
    Jun 2008
    51
    You might look at the resolver. My 4020 had one axis that generated a high follower error that could not be adjusted out. The resolver was pulled and had a bad bearing. Once replaced, the follower error was reduced to where it could be balanced. A lower reading might also be attributable to a bad resolver.
  1. TB6560 Blue dummy "load" to prevent damage.
    By danparker in forum Stepper Motors / Drives
    Last Post: 08-17-2014, 03:13 PM
  2. Replies: 2
    Last Post: 06-26-2014, 02:07 PM
  3. 4th axis controller 1010-5D jumper socket
    By timo2le in forum Fadal
    Last Post: 01-05-2014, 06:34 AM
  4. Removing 4th Axis (need to make dummy plug)
    By laka in forum Cincinnati CNC
    Last Post: 11-25-2011, 12:45 AM
  5. Fadal 4th axis dummy connections
    By RKR in forum Fadal
    Last Post: 07-04-2009, 11:18 PM
