587,409 active members*
3,493 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Arrow 500 encoder alignment for vickers drives
Results 1 to 7 of 7
    Jan 2009
    4
    Hello All,
    I have a new to me Cincinnati arrow 500 with the A2100 controls year 2000 model and the white and blue vickers drives. The drive for the z axis is model AS10302. I have been working through problems trying to get it to run. I got to the point where i was trying to align the machine and had a z axis brake issue that i resolved but in the process i did something dumb and removed the encoder off the z axis motor to get to the brake assembly. (brake was fine, other problem) I am now aware of what a mistake that was. So i now have the drive hooked to a laptop with motion link pulled up and am able to connect to the drive after doing the echo 1 thing. I can get to the screen that shows me the the encoder type, halls, enc start, enc init, and zeroing. I have the drive off of the machine and have been able to enable it and do the zeroing current and the motor twitches. My problem is i dont know what to do from here. Does anyone have any experience realigning the encoders on these machines? mike_Kilroy the guy i need to talk to?
    Oct 2016
    106
    Re: Cincinnati Arrow 500 encoder alignment for vickers drives
    I have the procedure. I send u later.
    Wys?ane z mojego D5803 przy u?yciu Tapatalka
    Oct 2016
    106
    https://www.dropbox.com/s/fcvjhcxg20...ient.docx?dl=0
    Jan 2009
    4
    I could be missing something but that looks like instructions for the spindle encoder and im trying to align the encoder for the z axis motor.
    Oct 2016
    106
    Sorry, I wasn't fully awake.
    Sep 2010
    1765
    Simple at that point, no instruction manual needed...
    Turn zero on, motor locks to a pole. loosen the encoder mount screws and rotate it so the position feedback arrow points to 0 on the display. Tighten encoder. Done.
    Is the problem solved with mike_Kilroy's solution?
    Quote Originally Posted by Lambo429 View Post
    Hello All,
  1. Replies: 6
    Last Post: 05-25-2021, 09:05 PM
  2. Cincinnati arrow 1000 A2100 - having problem alignment
    By JFYM88 in forum North America RFQ's
    Last Post: 06-03-2017, 03:47 PM
  3. Cincinnati Vickers/Kollmorgen drives motors
    By petesurrey in forum Cincinnati CNC
    Last Post: 04-11-2017, 06:26 AM
  4. cincinnati arrow 500
    By sissax.aek in forum Community Club House
    Last Post: 01-03-2014, 11:00 PM
  5. trouble with alignment of a cincinnati arrow 1000 (1998)
    By aherrc in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2008, 11:20 PM
