Hi
I am a business man, with plastic injection and blow molding set up in karachi, Pakistan. Few years ago I bought 2 CNC machining centres and 1 milling. For the last few years I have been unable to run my CNC workshop effictively, that has lead me to outsource my machining and mold making. However, i have a never ending passion to optimize the CNC setup.
The problems I faced were basically human resorce. In Pakistan CNC designers and operators are scarce. Resulting in non efficaint and non competitive market.
Now I have decieded to outsource just the designing of the components and first I will learn the following things and then pass them on to my staff:
- to create punch and cavity (from part design)
- generate tool paths
- try to gain expertise with machining
I now feel i can not design compnents at present , so i shall first learn the things which will make me independent . Then slowly i will get towards designing.
I want help from you guys, as i have not decieded which software to use.
Also i wanted to know how i could learn the above mentioned steps.
Your kind help will appreciated.
P.S , my knowledge in CNC is limited to the following,
- made few macro programs
- used pro E , most of the time, but i can only create basic solid shapes, not very good at surfaces.
- Have not a lot exposure of tool paths. have only made few countors and other toolpaths.
