587,753 active members*
2,977 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Learning CNC with limited resources
Results 1 to 2 of 2
    Aug 2007
    1
    Hi
    I am a business man, with plastic injection and blow molding set up in karachi, Pakistan. Few years ago I bought 2 CNC machining centres and 1 milling. For the last few years I have been unable to run my CNC workshop effictively, that has lead me to outsource my machining and mold making. However, i have a never ending passion to optimize the CNC setup.
    The problems I faced were basically human resorce. In Pakistan CNC designers and operators are scarce. Resulting in non efficaint and non competitive market.
    Now I have decieded to outsource just the designing of the components and first I will learn the following things and then pass them on to my staff:
    - to create punch and cavity (from part design)
    - generate tool paths
    - try to gain expertise with machining
    I now feel i can not design compnents at present , so i shall first learn the things which will make me independent . Then slowly i will get towards designing.
    I want help from you guys, as i have not decieded which software to use.
    Also i wanted to know how i could learn the above mentioned steps.
    Your kind help will appreciated.
    P.S , my knowledge in CNC is limited to the following,
    - made few macro programs
    - used pro E , most of the time, but i can only create basic solid shapes, not very good at surfaces.
    - Have not a lot exposure of tool paths. have only made few countors and other toolpaths.
    Feb 2011
    0
    salam this is zahid saleem from lahore , i am designer & devloper of diffrent kind of automatic machinery , recently made 2 cnc router 3rd will be 5 axis Inshallah , you can contact me for any help this is my email [email protected] & here is my phone number 0321-4163320. take care ALLAH HAFIZ
  1. CNC Resources
    By jordantrainor in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-07-2008, 09:30 AM
  2. case resources
    By mvaughn in forum CNC Machine Related Electronics
    Last Post: 05-11-2004, 11:04 PM
  3. Gecko's limited to only 20A ?
    By samualt in forum Gecko Drives
    Last Post: 09-24-2003, 01:24 AM
