587,189 active members*
2,716 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Confusing Tool Path
Results 1 to 7 of 7
    Dec 2020
    4
    Post Confusing Tool Path
    I'm a new drawing program user. I've been having this issue (see uploaded file) with the tool path. It seems to happen when the area being milled is the same size as the milling bit. I'm thinking it has something to do with my tolerance setting but I'm not sure.
    Jun 2008
    1838
    Re: Confusing Tool Path
    No uploaded file ??????
    Dec 2020
    4
    Quote Originally Posted by The Engine Guy View Post
    Can you see a thumbnail? Its should only be a picture.
    Jun 2008
    1838
    Yes, can see an image but it is impossible to diagnose anything from that, needs to be the BobCAD file then the settings used can be checked.
    It may well be just a tolerance issue but usually trying to do an area that is the same width as the tool isn`t a good idea and Z level Rough probably wouldn`t be the best strategy, a ramping Contour might be better but can`t even see the Model so only guessing that you are trying to rough out a slot of some kind yes ???
    Put the file in a Zip folder and attach to your reply.
    Stay Safe
    Regards
    Rob
    Dec 2020
    4
    I attached a Zip File. See if that works.
    Sep 2020
    14
    I would use 2 axis profile rough using ramp for the outside dia, and advanced z level finish for the inside angle, selecting only the angled surface. I am not an expert though.
    Dec 2020
    4
    Quote Originally Posted by GCSRT View Post
    You might not be an expert but this worked. Thanks for the advise. Much appreciated.
    God Bless.
  1. Replies: 0
    Last Post: 06-28-2020, 06:47 AM
  2. Software/ Online tool to modify G-code for unidirectional 'Zig tool path'
    By eeu23b in forum Uncategorised CAM Discussion
    Last Post: 09-13-2017, 07:12 PM
  3. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
  4. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  5. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
