586,655 active members*
2,795 visitors online*
    Dec 2020
    How to cut a long foam hole - like in foam pool noodles
    Hello,
    I am new to laser cutters, I would appreciate any advise. What rig / machine would be working to cut 2 meter (7ft) long hole in polyurethane foam )?
    It would be similar to the foam pool noodle holes cut (z- axis hole), though my pieces are simply a rectangular full mattress block of polyurethane foam
    Thank you!
    Oct 2010
    46
    Re: How to cut a long foam hole - like in foam pool noodles
    cutting a hole long like this (2 meters) would need a pretty huge machine and some kind of weird jig system.
    I think what you should take a look instead is a hot cutting wire for foam. making some kind of tool that will go from
    one side to another and having a jig to hold down your material. The hardest part will be to make the gantry going back
    and forth holding the cutting wire tool
    Check from 9min23
    https://youtu.be/bqG5I7sl8kk?t=563
    having a perfect round tube wire cutting system with a gantry over your material could do it.
    I don't think laser is the good tool to do that. laser have focal point (steady work-to-material distance) otherwise the
    cut will get messy or not precise.
    AXYZ Millennium router CNC: https://goo.gl/gxvdcA
    Glass cutting CNC table: https://goo.gl/VrDqGD
    Dec 2020
    Thanks for the reply, that looks good and more practical. Some have said hot wire is not suitable for flexible soft polyurethane, I don't understand why, is it because of the fumes?
    Oct 2010
    46
    For sure it would be necessary to extract the fumes and/or use a high quality mask-respirator, the gas out from that will be dangerous.
    For the cost needed to try it on a small sample, you should try it and and see by yourself before going all in with a custom system for your project.
    I know some company cut polyurethane foam using waterjet cnc but the cutting thickness is not 2m for sure! Thats way too long for that, those waterjet do have some "focal point" too so I don't think it could work unless you make the cutting head go inside.
    Jan 2008
    940
    I would make a core cutter from some tubing like conduit just grind teeth in the end and use a drill
  1. Replies: 0
    Last Post: 10-17-2019, 08:06 AM
  2. Replies: 0
    Last Post: 04-02-2018, 02:48 PM
  3. Info on foam cutting bit - Long one
    By Docop in forum CNC Tooling
    Last Post: 05-24-2016, 03:36 AM
  4. Extra long round nose foam cutters
    By waterrat in forum Uncategorised WoodWorking Machines
    Last Post: 01-14-2016, 11:52 AM
  5. Extra long router bits for foam
    By xshaper in forum News Announcements
    Last Post: 10-14-2007, 06:45 AM
