587,172 active members*
3,501 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Info on foam cutting bit - Long one
Results 1 to 2 of 2
    Jan 2011
    30
    Hi
    I'm looking at the proper bit to cut foam, the Blue Dow foam for insulation house.
    I will do a stack or a big block of 4inch.
    I do have a 2.2kw spindle, so for a bit of about 3 to 4in long. I guess with a cutting flute of about 1in or so, what bit could it be the best ? I don't go over a 90ipm let say..
    A 3 flutes... or a 2 flutes... And all upcut ?
    Thanks for the tips
    Aug 2009
    655
    Re: Info on foam cutting bit - Long one
    Onsrud has some good foam cutters I use, can't recall number but its the 1/4 shank one.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  1. Extra long round nose foam cutters
    By waterrat in forum Uncategorised WoodWorking Machines
    Last Post: 01-14-2016, 11:52 AM
  2. RCH2030 CNC Cutting machines /Chinese cutting machine for foam
    By ROCTECH-Vicky in forum Roctech CNC Routers
    Last Post: 12-25-2014, 07:58 AM
  3. I'm looking for Info on CNC Foam for mold cutting for car parts ?
    By Calico in forum CNC Wire Foam Cutter Machines
    Last Post: 03-29-2014, 04:12 AM
  4. Sources for long-shank Burrs for foam cutting?
    By Deltic_Engine in forum Material Machining Solutions
    Last Post: 06-28-2012, 02:07 AM
  5. Extra long router bits for foam
    By xshaper in forum News Announcements
    Last Post: 10-14-2007, 06:45 AM
