586,655 active members*
4,888 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need Help Urgently
Results 1 to 7 of 7
    Jul 2007
    45
    Need Help Urgently
    Hey guys, Im using MasterCam X2 and I am trying to program a part for our Okuma-Howa lathe with a Fanuc Series O-TT Control. Im not too good at it but this is my first lathe program. Here is the problem, i draw up half the part, and create the program using that, but when it post the nc code, the x's are the actual diameter of the part, and i need it to put them out for the radius. I fixed the program by going through the entire thing and halfing all the x positions. Using g92's to specify x & z for each tool. What am I doing wrong in MasterCam, or is this something that I need to fix by modifying the post? Using Generic Fanuc 2x Lathe control, and Generic Fanuc 2x Lathe post. I've also tried using the lathe default with the MPLFAN post.
    Please Help
    Jon (nuts)
    Jan 2006
    4396
    Quote Originally Posted by makinoman View Post
    Please Help
    Jon (nuts)
    Have you tried asking on the Emastercam Forum? All the Gurus hang out there and a few here.
    Here is the Link
    http://www.emastercam.com/cgi-bin/ul...cgi?category=1
    Cheers!!!!
    Toby D.
    Schwarzwald
    www.refractotech.com
    Mar 2005
    461
    Yep, he was there already and I think he got what he needed.
    Jul 2007
    45
    Yep, went to emastercam.com earlier also, and got the info that I needed. It was in the post, and I got it fixed. One little variable in the post was all I needed to change, so I'm all good now.
    Jon
    Jan 2006
    4396
    Glad to hear your situation was addressed and solved. These Forums are a great tool in deed.
    Cheers!!!!!!
    Toby D.
    Schwarzwald
    Nov 2005
    244
    Changing post
    I was playing with the mill to use as a lathe. I had the problem with turning diameter equals X also.
    What needs to be changed in the post?
    Camtd,
    I'm not sure if this is what you are asking but at the bottom of the screen ,
    click Planes, in the middle of the list you will see lathe radius or lathe diameter this will change from X to D or R. or from Lathe to Top plane X Y. if you change views it will update as well. the settings for view is found in general machine parameters in control definition. I set up each machine definition for the view to update to when I change between machines, I.E. lathe to mill or mill to lathe each time I pick a machine it will go to the default view for that machine.
    [email protected]
    www.cad2cam.blogspot.com
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
  1. Urgently need some information...
    By Dave's_Not_Here in forum MetalWork Discussion
    Last Post: 03-21-2007, 06:31 PM
