586,966 active members*
2,896 visitors online*
Results 1 to 5 of 5
    May 2008
    266
    Cutting a Fusee on a lathe
    I'm looking into cutting a fusee on my lathe, but none of the available gcodes seem appropriate to do this.
    A fusee is just a thread that is cut along a curvy profile, unfortunately, synchronised G32/G33 codes are not set up to do anything but linear moves and so can not be used.
    A G95 feed-per-rev gcode would be ideal, except I don't think it is synchronised between passes.
    So the question is: Am I missing a trick, or if not, would it be possible to add a 'synchronised between passes' function onto the G95 gcode?
    Many thanks.
    Martin.
    Mar 2017
    1325
    Re: Cutting a Fusee on a lathe
    G95 already is synched between passes.
    May 2008
    266
    Oh man, that is great!, I'll give it a blast!
    Thanks very much for the implementation and the reply.
    May 2008
    266
    I tried this out today and it worked really well, tracing the curve exactly.
    The thread is nice and accurate too on parallel parts, but the one unforseen is that the pitch diminishes as the slope of the curve increases. I suppose this must be a function of the Z axis movement transitioning to the X axis to maintain a constant feed-per-rev along the toolpath.
    Some way to maintain a constant pitch along a particular axis (regardless of other axis movement) would be nice for this kind of job - if that could ever be possible, please.
    Martin.
    Mar 2017
    1325
    Try to interpolate arcs into series of lines, each one with its own speed?
    For example, line at 45°angle should have speed (K if you use G33) increased by factor 1.41 in order to maintain same pitch in Z direction.
  1. Do RPM's matter when cutting on a lathe?
    By MychesterCNC in forum MetalWork Discussion
    Last Post: 06-08-2022, 02:51 PM
  2. Cutting Ti on lathe
    By jrcflyer in forum Turning
    Last Post: 02-02-2021, 11:39 AM
  3. How do I use these lathe cutting tools? (What cutting tool is for what operation?)
    By Mike1000 in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2013, 08:56 AM
  4. Cutting lathe question
    By Mooping in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2010, 02:44 AM
  5. lathe oils (way, cutting etc) help
    By Speedygonzales in forum Uncategorised MetalWorking Machines
    Last Post: 07-12-2009, 12:41 AM
