586,655 active members*
3,150 visitors online*
    May 2007
    54
    do steppers go bad?
    my job requires repair of machines that have stepper motors. I have come across a few units that have weak steppers... I.E. they stop spinning under small load and just make a weird noise, reset and start again. I have taken the motor apart, cleaned and inspected, all looks good. i suspect the power supply or motor control circuits on the motherboard are bad... How can i diagnose my problem? There are multiple wires connecting to the stepper, can i just check for voltage? how to know which ones?
    Once you take a stepper apart, it will lose most of it's power.
    Mar 2004
    761
    Is there any way to magnetize the stepper motors?
    May 2007
    54
    why would they go bad? doesn't make sense to me
    Aug 2006
    2758
    They do go bad. I have replaced a few of them, mostly small Nema 17 steppers. The defect is similar, they begin to lose steps or resonate and stall. Once replaced everything works OK. Nevertheless, bad stepper is the last thing I suspect, it is not as frequent as bad drives.
    Jan 2007
    599
    what about over running? would this be a drive or motor problem?
  1. X3 Steppers
    By dneisler in forum Benchtop Machines
    Last Post: 04-23-2007, 08:27 PM
  2. STEPPERS Will Someone Please Help!!!
    By bill south in forum Stepper Motors / Drives
    Last Post: 08-29-2006, 01:55 PM
  3. Help with steppers
    By wallyh in forum Stepper Motors / Drives
    Last Post: 05-12-2006, 06:52 PM
  4. Help, what are these steppers?
    By ljogwin in forum Stepper Motors / Drives
    Last Post: 05-09-2006, 04:35 AM
  5. Steppers
    By JBV in forum Benchtop Machines
    Last Post: 09-16-2005, 07:13 PM
