587,235 active members*
3,673 visitors online*
    Jun 2013
    454
    Touch of Plate with axbb-e help needed
    G'day folks,
    I have an axbbe controller and wanting to add a touch off plate.
    Trolled the forums and it seems simple enough, watched and downloaded macro from you tube - Paul from cncnutz.
    Not happening for me atm,
    As I understand it,
    Connect wire to an input second wire to a ground.
    Configure uccnc input add port and pin active low and you should be good.,
    The axbbe inputs is confusing me I have inputs 11 to 16 with + and -.
    In my case Im adding wire to pin 11+ and a wire to a ground.
    configure uccnc pin 11 port 2
    I get a solid green light.
    Am I meant to wire the 11- to anything, I cant find anything specific to the axbbe so totally confused.
    Cheers,
    Steve
    Mar 2007
    2083
    Re: Touch of Plate with axbb-e help needed
    to use isolated input 11
    you need to connect 11+ to the +24V supply and 11- to the - 24V supply
    your limit switch needs to either break the +24V 0r - 24V connection
    this example in the manual shows the N/C switches breaking the negative connection
    Attachment 436894
    John
    Jun 2013
    454
    Quote Originally Posted by john-100 View Post
    Attachment 436894
    John
    Hey John G'day,
    Thank you for taking the time to reply.
    I did try that, but for what ever reason when trying to set the ports and pins it would not allow me to set pin 11 port 2 it would only let me set pin 11 port 3 but port 3 is where my UCSB sits. The axbb box clearly says the inputs are port
    I did get it going but I ended up using the UCSB attached to the axbb which was fine with the pin and port setting.
    Just got in from the garage not so happy having to nut that out.
    Thank you for the link, I had the manual already.. the issue in the end was when uccnc wasnt going to have a bar of port2.
    Cheers,
    Steve
    Jun 2015
    943
    Your problem is that on the AXBB-E there is no pin 11. in the port#2, but it is I1 in other words Input1 and not 11.
    Just like how there is I2 and not 12.
    Jun 2013
    454
    Olf well bugger,
    Ok that makes sense sigh, well I could have been reading that until all the cows from back home arrived and would never have known.
    Thank you very much, I do wear glasses nowadays for reading I guess not strong enough. I have been reading them all as 11, 12, 13, 14 etc well !#@$!%!^! ....
    Olf I appreciate your taking the time to reply, now I can go sit in my workshop and look stupid on my own for a half hour or so..
    Cheers,
    Steve
  1. my AXBB-E and UCSB are on the way, small annoyance is anyone using axbb with mach3?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 05-17-2019, 03:50 AM
  2. Little help for touch plate
    By abeekaushik in forum Open Source Controller Boards
    Last Post: 06-10-2018, 09:39 AM
  3. z touch off plate
    By Alwaysintheknow in forum Chinese Machines
    Last Post: 06-10-2013, 03:20 AM
  4. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  5. Touch off plate
    By rich_cree in forum Benchtop Machines
    Last Post: 06-03-2010, 06:05 PM
