586,937 active members*
2,093 visitors online*
Results 1 to 20 of 22
    Jun 2003
    2103
    slice command
    I noticed someone mention a slice command and I have not been able to find it . Where is it located and how to use it please!
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Sep 2003
    363
    Slicer is a plugin for Rhino if your into boat hulls.
    http://www.rhinomarine3d.com/
    Gary
    Jun 2003
    2103
    Well that pretty well fixed me! I just don't think a guitar would look good shaped like a boat .......on the other hand wallcrawler wanted us to get outside of the box.......hmmm.
    Gary will it work for any application? For instance......I make a solid of the guitar body that is too tall and lay the shape from the end and side view...would the slice command fix it...as in take out the uncessary solid above the profiles that were drawn for the end and side view?
    Mike
    .......did wallcrawler say out of the box or out of the boat
    Sep 2003
    363
    TRIM! Your looking for the trim comand. You can create a surface that slices thru your solid and then trim the solid on either side.
    Gary
    Sep 2003
    363
    A solid.
    Sep 2003
    363
    With a surface thru it.
    Sep 2003
    363
    Trim.
    Sep 2003
    363
    Delete the surface.
    Mar 2004
    1147
    question - i am looking into a way to slice a 3d model into many thin layers to start work on some additive rapid prototyping experiments. i want to try and bring additive RP to the DIY lexicon. in addition to the flatbed gantry printing....
    anyone know about slicing a 3d model into.. say.. .05" thick slices...
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
    Jun 2003
    2103
    duluth I didn't need an egg! Ok give me a little bit and I will do a screen shot, I hope, to kinda show what if I understand or not.
    edited: that was supposed to be "what or if"
    vac check into the rapid prototyping arena. I think that is how they lay a plastic or wax prototype. It might just be what you are looking for. Way beyond my comprehension or understanding either .
    Mike
    Sep 2003
    363
    Vac,
    In Rhino you could the use splitting command. Create a surface that would cut to the extent of the object. Then use the array command to place the surface every .050. Then split. At that point you could pull out the individual segments.
    Gary
    Sep 2003
    363
    Sorry Mike I didn't have a guitar.
    Gary
    Aug 2003
    26
    The easiest way in rhino would be to use " section " on the " curve from objects toolbar ----or you can find it on the bottom of the curve dropdown menu . set your grid snaps to the distance that you want the section offsets to be . ---Sometimes I draw a construction line through the object that I'm trying to section and use the object snap set to " end " --You can ofset the construction line using the offset command to whatever distance you want and make multiple slice guide lines through the object . Using the construction line method the slices can be at any angle through the object that you want . One trick that I've found usefull for extracting frame sections from a boat hull is to set the current layer to the first frame , then create the first section . Then without exiting the " curve from object " command change the current layer to the second frame , create the next second station , etc . ---this way all of the sections can be put on their own layer . ----Layers are a powerfull tool get in the habit of using them . I use two monitors and keep the layer dialogue box expanded on the second screen .
    Jun 2003
    2103
    Uh.....windsor thanks for the help but....what did you just say ? You just have to remember I am older than most here, brand new to Rhino and a redneck! I just barely have one moniter but I did actually see the need for two or more the other day while thrying to work on two drawings at the same time to do some comparisons. I actually have a friend doing this project for me but I am still wanting to know how to do it as well as all the other good stuff. I will try your method and see if I can get it to work for me.
    Mike
    Sep 2003
    363
    Hi Mike,
    I’m old to, so I know anyone can learn this. I have learned many things looking for solutions to questions from others. In your case I’m not sure we are going down the same track. Maybe an example would clear things up. Can you post a pic?
    The process that Windsor describes is a very good way to extract section lines from a solid.
    Vac,
    Below is some shots of a way to extract sections from a solid.
    Sep 2003
    363
    The object and splitting surface.
    Sep 2003
    363
    Array the splitting surface.
    Sep 2003
    363
    Split and seperate.
    Gary
    Aug 2003
    26
    I have a jpeg , but I'm not sure how to attatch it ?
    Use the "Post Reply", bottom right of the last post.
  1. single line fonts?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 02-18-2006, 06:51 PM
  2. Test for moving ?
    By murphy625 in forum CamSoft Products
    Last Post: 04-04-2005, 03:02 AM
  3. Command Post for Mach2 Help??
    By foamcutter in forum Mach Software (ArtSoft software)
    Last Post: 07-17-2004, 08:35 PM
  4. Line command
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 06-26-2003, 08:42 PM
  5. fanuc servo motor moving without command
    By mtech in forum Uncategorised MetalWorking Machines
    Last Post: 06-17-2003, 02:39 AM
