587,872 active members*
3,385 visitors online*
    Feb 2005
    117
    Mini Dell Computer , Lost the Mach 3 license
    I purchased a mini Dell computer and monitor from CNC4pc. several years ago. We had some problems with
    unit losing the software and sent it back for repair.
    Never used it until now as we had a spare unit so wound up shelving it as a backup.
    Went use the computer and found that Mach3 had been loaded on the machine and will only
    run in demo mode. Is the license on the unit ?
    Do I have to buy another license ?
    Thank you
    Re: Mini Dell Computer , Lost the Mach 3 license
    In Mach3 the license is not associated to the PC, but the installation. You just need to copy the license back into the Mach3 root directory. If you do not have the license, open a ticket in the cnc4pc and it will be sent to you again.
    Arturo Duncan
    https://cnc4pc.com
    Feb 2005
    117
    Thank you for your response Arturo.
