Wow, that is a bummer!
First off, try a reset of the main panel circuit breaker and a reset of the breaker supplying this particular machine. A partially tripped breaker could possibly be causing loss of one phase.
With power disconnected, I would remove the power leads coming in to the main transformer in the control cabinet. Check between each terminal of the transformer with an ohmmeter, to ground, to see if the transformer has a short circuit.
Could possibly be damage to the spindle inverter although I would hope it would come on with an alarm first.
There are other, smaller power supplies in the cabinet, too. In my 1996 VF3, there is a basic PC power supply for the computer circuit boards, and another small power supply for control circuits of the servo cards. Those may have been affected, but I doubt that they would cause a main short that would blow your fuses.
