587,072 active members*
3,075 visitors online*
    Apr 2013
    9
    mori nv5000 bleeding charge tank
    I am having trouble getting my knock out cylinder to extend all the way down so I can insert the retention knob in to the fingers of the drawbar. I have been bleeding the charge tank half the day. It only needs to go down another 1/8 inch. We just changed the Bellville washers and fingers. Has anyone seen this problem before? Do I just keep bleeding and adding oil some more?
    Thanks Mercman
    Feb 2009
    6028
    Re: mori nv5000 bleeding charge tank
    Yes. MDI mode-open bleeder, close bleeder, manual mode, tool unclamp/clamp a bunch of times, rinse and repeat. Now, if the Lucifer valve is failing/failed, all bets are off. Did you replace O-rings? Lots of grease? Was the drawbar shaft scored? Mori springs or aftermarket like Key Bellville? Aftermarket ones usually need to be deburred on the inside.
  1. Mori NV5000
    By damnifiknow1 in forum Mori Seiki Mills
    Last Post: 10-09-2014, 03:37 PM
  2. mori nv5000 nv501bfo338
    By Damnifiknow in forum Mori Seiki Mills
    Last Post: 11-29-2012, 04:12 PM
  3. Need Help on Mori Seiki NV5000
    By dannifer.ebot in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2010, 07:45 PM
  4. Bleeding clamp cyl. on mori jr
    By mkeoj in forum Uncategorised MetalWorking Machines
    Last Post: 03-25-2009, 02:19 AM
  5. G08 on mori NV5000
    By Mill Guy in forum Mori Seiki Mills
    Last Post: 10-25-2008, 12:02 AM
