587,229 active members*
6,282 visitors online*
Results 1 to 20 of 22
    Mar 2013
    344
    No Path Pilot for Rapid Turn?
    I finally got around to trying to do something useful with Rapid Turn. Well, I didn't get very far. Actually I got nowhere. It seems PathPilot supports the Duality but not the RT. Still, I took a look at Duality's conversational app in PP. It's a nightmare. For a simple facing operation it asked more questions than my wife does when I come home late.
    Ultimately, all I want to do is to face, drill, turn two o/s diameters knurl, chamfer, and part. Something easily accomplish on my 14x40, but since I need quite a few of the parts, the RT seemed appropriate. Had to take the family out to eat so had no time to try to manually write the code. That left me wondering will PP/RT even support standard lathe g-code?
    Nov 2012
    591
    Re: No Path Pilot for Rapid Turn?
    The page for "rapidturn upgrade from duality" says explicitly:
    "RapidTurn™ requires PathPilot"
    So ... there's probably some setting or configuration needed, but Rapid Turn should be controllable from the PathPilot.
    Maybe you checked an old version? Or maybe the duality/rapidturn are just the same module?
    Apr 2008
    19
    What version of PathPilot are you using? PathPilot has been set up for Rapidturn for quite awhile. I attached a screen capture of a older 2.0.x version, not sure if the picture will come through, but it should say RAPIDTURN in the lower right hand corner of the screen. If it doesn't, I suggest that you upgrade at least to V 1.9.13.
    https://www.tormach.com/support/soft...release-notes/
    Attachment 409036
    Mar 2013
    344
    Quote Originally Posted by Sir John View Post
    Attachment 409036
    Thanks, I'm using ver 1.7.2
    Apr 2008
    19
    That is a pretty old version. try updating to at least V 1.9.13 and see how it goes for you.
    Jul 2004
    1424
    Pathpilot version 1.7.2 (which you are using) was released on 15 April 2015.
    The RapidTurn product was released in June 2016, and a new version of pathpilot was released to support RapidTurn at that time.
    Like others have said, update RapidTurn!
    I would strongly suggest you go to the current version, which will require you to buy a USB stick from Tormach (version 2.0 and above installed a new Linux OS, and required an install USB stick for that).
    Tim
    Mar 2009
    1863
    I’d like to try Rapid Turn, but it’s not compatible with my MACH III, and as long as my MACH III still works, why change.
    Apr 2013
    1788
    Quote Originally Posted by Steve Seebold View Post
    Perhaps you should change because you would like to try Rapid Turn?
    Mar 2013
    344
    All's good now. i down loaded the last 1.9 version and RT is alive and well. I''m too much of a cheap skate to pay $100 for the 2.x version on a USB stick. And unless there is a compelling reason to do otherwise, like recognizing my pendant, it will never happen.
    Apr 2013
    1788
    Actually only $24.95 for 38249 - PathPilot v2.0 Upgrade
    Mar 2013
    344
    Why so many updates? Shouldn't they have it right by now?
    Apr 2013
    1788
    Quote Originally Posted by jttoner View Post
    Many of the updates have been to add new features or to support new products such as the 1100M. So far, all updates have gone smoothly and not caused me any grief. I prefer to use a product with frequent improvements rather than a dead product like Mach3 that hasn't changed for years. That said, there is no obligation to accept an update to PathPilot. If an update causes a problem or you don't like an improvement you can always revert to a previous version. What do you consider the problem to be?
    Mar 2013
    344
    Many of the updates have been to add new features or to support new products such as the 1100M. So far,nall updates have gone smoothly and not caused me any grief. I prefer to use a product with frequent improvements rather than a dead product like Mach3 that hasn't changed for years. That said, there is no obligation to accept an update to PathPilot. If an update causes a problem or you don't like an improvement you can always revert to a previous version. What do you consider the problem to be?
    What problem? I just asked a civil question. So one of the updates added support for a few new machines, that's a good thing. At least the updates for new features aren't mandatory, unlike Windows 10 or ATT Mobile, both with their never ending mandatory updates.
    Do have a pleasant day and a happy new year.
    Apr 2013
    1788
    I apologize if you found my comment offensive; it certainly wasn't intended that way!
    Oct 2012
    42
    It's nice to see software supported by a company that solicits suggestions for improvements and features and makes updates available for free https://www.tormach.com/support/soft...lot-bugreport/
    And has a video soliciting improvements. I think it's a sign of a conscientious company that doesn't consider something as crucial as software ever being right by now. The updates/upgrades being free is icing on the cake in my view.
    https://www.youtube.com/watch?v=puZednzlsY0
    Oct 2010
    670
    Quote Originally Posted by cncoperator View Post
    Agree with you 100%. JTTONER - I would hope if you make a product that you would always be looking to improve it, regardless of how long you've been improving it. I also like the fact that they do not wait for months on end to add bug fixes and request just so they can say they only pushed out "1" update this year. Keep up the great work Tormach! They are not perfect but at least they are listening to the customer!
    The Body Armor Dude - Andrew
    673
    lol. why do they keep making new model cars? TVs or anything else? Time, tools, technology and requirements change as does everything else.
    Mar 2013
    344
    Quote Originally Posted by Spinnetti View Post
    Okay, I'll bite. Just what super-duper new technology am I missing with PP 1.9.13? Will the latest and greatest run my pendant?
    Apr 2013
    1788
    Yes if your pendant is the one that Tormach sells!
    Oct 2012
    42
    Okay, I'll bite. Just what super-duper new technology am I missing with PP 1.9.13?...
    (And from an earlier post)...That left me wondering will PP/RT even support standard lathe g-code?
    It's not just the super-duper new technology you're missing if you're not running the latest version. You can't help improve PP which would benefit all of us. For example if there is a problem or feature request with the most current version it makes sense for Tormach to look into it. If you're running an out of date version it's not a productive use of time to respond to an issue such as Path Pilot not supporting Rapid Turn that has already been addressed.
  1. Tormach Rapid Turn / Path Pilot parting question/ bug??
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 08-30-2016, 06:08 AM
  2. Got my Path Pilot
    By BIG IGG in forum Tormach PathPilot™
    Last Post: 02-10-2016, 03:06 PM
  3. Path Pilot Thread
    By Steve Seebold in forum Tormach Personal CNC Mill
    Last Post: 01-26-2016, 04:37 PM
  4. --Unlocking Path Pilot--
    By Jim Anderson in forum Tormach PathPilot™
    Last Post: 09-19-2015, 04:32 PM
  5. Path Pilot - Rasberry Pi 2 b
    By tosatool1 in forum Tormach PathPilot™
    Last Post: 03-19-2015, 08:07 PM
