587,021 active members*
5,909 visitors online*
    Dec 2006
    13
    G31 uses machine coordinates?
    I have successfully connected a touch probe to the accessory socket, but the coordinates of a successful probing are not as expected. I do this:
    g0 z0
    g31 z-0.5 (probe downward)
    After the probe trips, parameter #2002 is supposed to be the Z coordinate of the location at the time the probe tripped (section 7.7.12 of the manual). And so I expect this command to do nothing:
    g0 z#2002
    If the program coordinates are the same as the machine coordinates, then the result of the g0 above is just a *tiny* movement, probably correcting for the probe having overshot or having backed off slightly.
    But if the program coordinates are not the machine coordinates, the command g0 z#2002 causes a downward movement.
    1. Is this expected operation?
    2. Am I using g31 correctly?
    3. What is the best way to get the program coordinates of the probing?
    Kerry
    Dec 2006
    13
    I've confirmed through the MDI in the Offsets screen of Mach 2 that G31 definitely returns its probe results as machine coordinates. I can program for machine coordinates (yuck!), except that the tool-length offsets won't be automatic. Unless there's another way to do this, I'll end up copying tool length info into the G-code program, and I'll always need to confirm that the work offsets are 0,0,0 before running the program.
    I hope there is a better way. I'll post what I learn.
    Kerry
  1. FanucOM machine coordinates
    By bcdnm in forum Fanuc
    Last Post: 10-28-2012, 03:20 AM
  2. Help - Problems with Z coordinates in g code
    By Socalsurferx in forum G-Code Programing
    Last Post: 03-12-2006, 11:12 AM
  3. Sending the table to the zero coordinates?
    By saturnnights in forum Mach Mill
    Last Post: 02-28-2006, 06:07 PM
  4. Help!! Problem With Z coordinates in G code
    By Socalsurferx in forum Mastercam
    Last Post: 01-30-2006, 06:24 AM
  5. Coordinates modal and / for rapids
    By HuFlungDung in forum OneCNC
    Last Post: 04-05-2003, 04:42 AM
