587,529 active members*
3,286 visitors online*
Thread: C11G axis
    Feb 2005
    117
    C11G axis
    Could someone tell me the number of axis that can be controlled through the C11G break out board ?
    thank you.
    Re: C11G axis
    It is intended for 4 axes. You could use up to 6, but then you will have to use pins that are intended for a different use. Like the Safety Charge Pump, Spindle Control, or Relays.
    If you need more than 4 axes, there are other more appropriate boards.
    If you open a ticket on our website and tell us about your project, we will send you recommendations:
    https://cnc4pc.com/contact/
    Arturo Duncan
    https://cnc4pc.com
  1. NM-145 and C11G BOB Questions
    By Krenovian in forum Novakon
    Last Post: 11-08-2013, 03:16 AM
  2. WTF C11G Gecko 203V
    By georgeburns in forum DIY CNC Router Table Machines
    Last Post: 11-02-2012, 03:34 AM
  3. CNC4PC C11G BOARD
    By MegaMoog in forum Benchtop Machines
    Last Post: 05-05-2010, 09:29 PM
  4. c11g vfd direction control
    By doc0302 in forum Automation Technology Products
    Last Post: 08-16-2009, 06:30 AM
  5. Relé interfase C11G
    By fenixes in forum Spanish
    Last Post: 05-16-2008, 06:29 AM
