587,453 active members*
4,431 visitors online*
    Nov 2015
    G10 L2 not working, MF-T6
    When I command, e.g.:
    G10 L2 P1 X1.0 Z1.0
    WCS does not change, if I check work coordinates G54-59 all of them still are 0.0, control does not pop any alarm
    I do not know if control is capable to admit G10 or there is a parameter that has to be set in order to admit the changes
    is there another way to specify the WCS without the usage of G10??
    Thank you in advance,
    2932
    Re: G10 L2 not working, MF-T6
    According to my F6M-B manual, G10 was an option. I'm surprised you don't get an alarm. Maybe your control has the Custom Macro option installed. If so, you could assign G54 X and Z with a macro statement, i.e.:
    #2401=1.0 (G54 X)
    #2701=1.0 (G54 Z)
    Check your 6T manual (I don't have one), to see if these variable #s are different for a T model than an M.
  1. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  2. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  3. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
