586,700 active members*
2,933 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > 3d roughing problem
Results 1 to 9 of 9
    Mar 2011
    273
    3d roughing problem
    Hi all, I am having trouble getting a simple angle roughed out with an end mill, it will just not go all the way to the end of the part, unless I choose "3d extents", and when I do it rounds the edges which I do not want. I have attached the file, what am I doing wrong? I want this part to rough going from bottom up on the angle in a flat back and forth toolpath.
    thanks to anyone who can send me in the right direction.
    Apr 2009
    3376
    Re: 3d roughing problem
    You must be newer than V28,,can't open
    Is it possible with your particular design to simply extend surfaces and fake the software out ?
    Mar 2011
    273
    Yeah, v29. I can build the solid out to have it go far enough out, just was hoping there is an easier way as I have a bunch of parts to make (all different) that will need to be rough milled in the same fashion.
    thanks
    Doesn't V29 still have the "Extend Surface" function?
    In V25 I un-stitch the surface from the solid, make a copy on a new layer and extend the surfaces of that.
    Dec 2008
    4548
    You can drive it with a boundary too...
    https://youtu.be/xmaORlls_kE
    Mar 2011
    273
    Quote Originally Posted by BurrMan View Post
    I though the boundary was to keep it inside an area, learned something new. I tried what you did and still got it to curve over the edges with my current file, but unzipped the file I have on this site and did exactly what you did and now it is pretty dang close to what I had been attempting. Thank you all, I will need to practice this a bit more on the other parts and see if my success rate improves. Glad to have all you guys on this site to help people like me out
    Dec 2008
    4548
    Select the toolpath that allows it to go to where you want, the boundary needs to limit it's ability to "drop off the corners or edges you don't want it to"... So you can draw ANY boundary, it just has to allow the surface to be cut by the tool, but not give enough room for it to go where you don't want...
    Jun 2006
    143
    If you don't want it to drop past a certain point then use the depth options and set a bottom of job depth, this will make it so the tool path will not go below that distance.
    Dec 2008
    4548
    Quote Originally Posted by Malish View Post
    The issue was to drive the toolpath DOWN FURTHER without rolling the edges... FYI
  1. Problem with G72 roughing cycle ST-30
    By JohnF in forum Haas Lathes
    Last Post: 08-17-2016, 01:17 AM
  2. Roughing question/problem
    By jeanyes in forum MadCAM
    Last Post: 02-03-2013, 08:27 PM
  3. rest roughing problem
    By Joesph Jackman in forum Mastercam
    Last Post: 03-14-2012, 04:11 AM
  4. Postprocessor/roughing problem
    By tummen in forum EdgeCam
    Last Post: 11-08-2010, 10:49 PM
  5. Roughing Toolpath problem!
    By billlaws in forum Mastercam
    Last Post: 12-03-2009, 11:15 PM
