587,771 active members*
2,925 visitors online*
IndustryArena Forum > CAM Software > Alphacam > siemens 810 mill post for alphacam
    Aug 2007
    18
    does any "non commercial" person have a copy of this and would be willing to share for sensible donation.
    Feb 2018
    59
    Re: siemens 810 mill post for alphacam
    hey there,,,i can easily create the code for you,,,,can i have details about the machine,,,,
    keysoftwareservice.com
    Apr 2010
    89
    Attached is a Post I wrote for a 3-axis OOYA Drill/Mill Bridge type machine with a Siemens 810M Control.
    There will be some machine specific code that might need changing to suit your machine, you will also need to change the following sections of the Post to suit your machine
    $743 Maximum Spindle Speed
    $744 Fixed Speeds (As our machine had fixed Speeds, set to zero for Variable Speeds)
    $753 Maximum Feed Rate
    $900 XY Rapid Speed
    $901 Z Rapid Speed
    Let me know by PM if any changes need to be made.
    Frank.
    Apr 2015
    327
    In a attachement you can find VBA post for Sinumerik 840D, it is very similar.
    If you will need some changes write me.
    https://www.dropbox.com/s/43xsdr9rvw...0_XYZ.amb?dl=0
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Aug 2014
    hi
    i need a
    siemens 810 M mill post for Autodesk PowerMill
    thank you
  1. Replies: 0
    Last Post: 02-17-2018, 07:10 PM
  2. siemens mill tap 700 post
    By MACHINEFREAK in forum GibbsCAM
    Last Post: 09-11-2014, 01:53 AM
  3. Alphacam 2013 ultimate mill problem
    By jona in forum Alphacam
    Last Post: 11-03-2013, 08:19 AM
  4. configuring Alphacam postprocessor for 5 axis mill
    By bimbi.tmp in forum Uncategorised CAM Discussion
    Last Post: 03-28-2013, 12:15 PM
