587,770 active members*
3,087 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact with Heidenhain 145 - Z Axis weird problem
    Nov 2017
    Hi All,
    I am having problems with homing the Z axis on the above machine.
    The problem started with the Z axis struggling to rapid Z+ but Z- was ok. Turned out to be worn brushes in the SEM Axis DC Motor. These have been replaced and the machine put back together. (All wiring is correct as photos were taken before removing any wiring).
    Now the machine is back together, when homing the axes the X & Y home fine but the Z now tries to home in the minus direction? and never homes but just hits the limit stop. The axis stops but the "Pass over Z-refenence Mark" message remains on the screen?
    We have checked the Bosch axis boards and all 4 lights on them light up when homing.
    We have removed the lid from the encoder on the Z motor and LED is on on the pickup
    We have tried changing the software limits but had no effect
    We have also changed the counting direction for the Z axis in the parameters and that does reverse the Z motor but just hits the Z+ limit stop
    Does anyone have any ideas as it is doing my nut in!!!
    The machine worked ok previously until the Z+ rapid (anything over 500mm/min) error started happening.
    Sep 2005
    250
    Re: Bridgeport Interact with Heidenhain 145 - Z Axis weird problem
    I would try switching the Z axis drive board with one of the others and see if the problem stays on the Z
    Jul 2014
    22
    sounds like a sticky limit switch.
  1. Bridgeport Interact 520V/Heidenhain TNC155Q problem
    By RS232 in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2016, 07:47 PM
  2. Bridgeport Interact 1Mk2 Heidenhain TNC151 4th axis encoder problem
    By hazelchase in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2014, 04:27 PM
  3. Bridgeport Interact 412 Heidenhain 2500 control 4th Axis ?
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 01-05-2014, 05:16 PM
  4. Bridgeport s II interact II z-axis HEIDENHAIN
    By bigtoad170 in forum Bridgeport / Hardinge Mills
    Last Post: 05-19-2008, 01:15 AM
