586,754 active members*
7,404 visitors online*
    24223
    Info Wtd on serial EEprom
    Anyone have any experience with serial eproms the likes of X25C02 & X25040?
    My programmer does not list the X25C02, only the X25040.
    They appear identical in just about every way except the first is 256X8 and the second is 512x8 (2k & 4k).
    My question is, if I plug in a programmed ,40 into a system to replace an ,02, is there any forseeable problems, when it comes to reading?
    Al.
    Jan 2007
    355
    Al,
    It really depends on how the system software is accessing the eprom.
    When you program the chip, duplicate the data from addresses 0 thru 255
    to addresses 256 thru 511
    This will prevent any problems from address counter rollovers or an improperly set high address bit.
    If the system is only reading and not writing to the chip, you should be OK.
    24223
    Thanks, I will try that, it is only reading in the system.
    Al.
  1. Need some help with Ethernet-to-serial
    By kingneutron in forum Computers / Desktops / Networking
    Last Post: 11-29-2006, 08:49 PM
  2. Serial cable help
    By turbo_todd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-12-2005, 03:52 PM
  3. Parallel to Serial
    By cbcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-09-2005, 04:21 PM
  4. Serial CNC Software?
    By Ian Cunningham in forum Uncategorised CAM Discussion
    Last Post: 08-02-2005, 02:18 PM
