587,773 active members*
3,413 visitors online*
Results 1 to 4 of 4
    Serial CNC Software?
    I'm a total CNC newbie, and I've just build a cheap Milford CNC machine (1/2 way down this page : http://www.milinst.com/robotics/robotics.htm)
    However, the included software can only plot HPGL files which is no good for my gcode PCB files. Is there any way I can either convert them, or plot gcode directly to this machine?
    35538
    Your best bet would be to buy a HobbyCNC or Xylotex parallel port driver board that will let you use TurboCNC or Mach3 to control the machine.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Ah, so there is no software solution to do it with the current board?
    35538
    Not that I'm aware of for less than $1000
    Gerry
