586,647 active members*
2,332 visitors online*
    Sep 2017
    5
    Question Can UCCNC do this? 2 head plasma
    I want/need to retrofit a large (14'wide gantry) ESAB Avenger 1 Plasma table with two 600 amp heads that was purchased at auction.
    I have been looking at my options. With MACH4 I could maybe get the second head to work as a slave to the first one and just have another setup when only using one head. Pretty much leaning towards VitalSystem complete Ethernet closed loop system with Yaskawa drives. if I go this direction.
    I want to keep this as simple (Ethernet wherever possible) and professional as possible not worried about saving a few dollars here and there. But, am an experienced programmer so having the power and flexibility these "hobby" systems provide is very attractive... Oh saving $50K is not bad either.
    So far it seems to me UCCNC is a replacement for Mach3, and is still all serial cable stuff???
    SO: Would like direction on:
    Which software to use for plasma?
    Are two heads possible?
    If I do go CNCNC, what is the simplest closed loop cards that are recommended?
    What THC with that card system?
    Thanks much for anyone's time and input.
    Jun 2015
    943
    Re: Can UCCNC do this? 2 head plasma
    I use UCCNC and UC400ETH on my plasma machine which is an ethernet motion controller for uccnc and with NeuronTHC which is an ethernet THC controller.
    I have one head only on the machine, but I think 2 heads should be no problem.
    You could use the swapaxis function of the uccnc and an offset.
    Apr 2013
    1899
    Quote Originally Posted by scubawarm View Post
    I can't help you with the plasma questions, but what do you mean by this question? UCCNC has never been serial cable type. They have USB and Ethernet controllers. UC400 and UC300ETH are the two types. I have a UC300ETH and very happy with it.
    Aug 2007
    55
    Im building one at the moment, uccnc, neuron thc, hypertherm.
    Jun 2015
    943
    That's a nice machine base, but what is the weight of the gantry?
    It looks a bit overly robust to me for a plasma machine.
    Apr 2014
    215
    With uccnc you can have 6 axis ...
    What you do with them is up to you, and all depends on how you set your post processor up.
    If you are using Neuron torch height controllers... This will mean that your z and z1 axis become free... So that would give you technically 8 axis control
    I presume you will have two servo motors for the Y and y1 axis, and 2 or 4 for the X axis.
  1. UCcnc and PLASMA
    By vmax549 in forum UCCNC Control Software
    Last Post: 08-25-2018, 04:19 AM
  2. UCcnc Plasma features
    Last Post: 07-28-2016, 07:48 PM
  3. Floating head touch off script for UCCNC plasma
    By Greolt in forum UCCNC Control Software
    Last Post: 01-04-2016, 04:56 AM
  4. Doing my head in with Z speed uccnc mach. Speed Feed
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 12-26-2015, 02:14 AM
  5. CNC Router Want to Add Plasma Head Questions and Help.
    By Cartierusm in forum Waterjet General Topics
    Last Post: 10-13-2010, 05:19 AM
