586,971 active members*
2,965 visitors online*
Hybrid View
    Jan 2017
    Exclamation Charter Oak IH6000 - runaway table
    While doing some routing milling, suddenly my table went at full speed in the negative x axis until it hit the external stop. Turned it off, waited, rebooted, same thing. Driving it with Mach Three software, factory installed. When I launch software and reset, the second I try to move table in positive x, it kicks in to negative x movement, then shuts down immediately, because it is already at the stop. Need help isolating the problem. Software? Cabling? Controller?
    Nov 2003
    287
    Re: Charter Oak IH6000 - runaway table
    If servo machine. The first thing I would check is the encoder and or cabling for the x motor.
    Jun 2005
    1730
    You might want to disconnect the motor from the axis while you troubleshoot the issue. As vertcnc said if this is a servo system a bad encoder could send it seeking.
    Russ
  1. New X4 Speedmaster From Charter Oak
    By Bob La Londe in forum Charter Oak Automation Support Forum
    Last Post: 06-08-2016, 07:22 PM
  2. WHy Charter Oak CNC MILL?
    By new2cnc4 in forum Charter Oak Automation Support Forum
    Last Post: 02-08-2016, 04:46 AM
  3. Replies: 0
    Last Post: 04-21-2015, 11:24 PM
  4. Syil CNC at Charter Oak
    By tmarks11 in forum Charter Oak Automation Support Forum
    Last Post: 03-30-2015, 12:49 AM
  5. Charter Oak Automation
    By saabman in forum Charter Oak Automation Support Forum
    Last Post: 04-11-2013, 07:27 PM
