586,929 active members*
2,806 visitors online*
Thread: MDF Sucks
Results 1 to 20 of 39
    Jun 2006
    217
    MDF Sucks
    Is there a preferred bit to cut MDF.............I wan't to cut out numbers, shapes etc.
    Also, is there a good sealer to seal MDF prior to spray painting? It just sucks spray paint in. I'm thinking of a dip ................any ideas? thanks
    If you're talking about the top edge being rough, you can use a downcut spiral. Unfortunately, downcut spirals tend to get dull rather quickly. MDF in general tends to dull tools quickly. For best results, always use very sharp tools.
    Dec 2005
    390
    Quote Originally Posted by monte55 View Post
    I have used spray-bomb enamels - those left a horrid finish on MDF - and oil based brush-on enamels - OK, still sucked the paint pretty good. If I ever paint MDF again I would be inclined to try spraying with an epoxy primer initially.
    Oh, for some project I tried to seal MDF using polyurethane. That was REALLY sucked up. Sealed up really well but the finish was rough.
    Hope this helped.
    Jul 2005
    668
    Seal the edges and the cuts with a mixture of 4 parts water and 1 part white or yellow glue.
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    1230
    I find shellac based sanding sealer good.It may need to be thinned but one good coat,left to soak in and then when thoroughly dry,de-nibbed with 150 Fre-cut paper works well.
    Dec 2005
    1408
    Quote Originally Posted by Madclicker View Post
    I use a couple of coats, and de-nib with 240 grit paper. If you use steel wool after the second coat, you can get the edges of MDF really smooth.
    I use a spirit based primer.. I've never had much luck with the water solvent quick-drying stuff.
    Best wishes
    Martin
    Jun 2003
    2103
    Take a few minutes and look this site over. This type finish is the best there is for mdf.
    Mike
    http://www.seagravecoatings.com/polyeste.htm
    No greater love can a man have than this, that he give his life for a friend.
    But I bet that would be some nasty stuff to apply in the garage.
    Jun 2003
    2103
    Prolly! But I use a home made booth of sorts and it, or rather a product similar to it isn't too bad.
    Mike
    Jul 2005
    298
    The best results I've had are with high solids 2-pack auto primer. Unfortunately, it uses an isocyanate based hardener, which is very nasty stuff.
    I'm still hunting for a product that will really coat edges of MDF (so that they can be finished glass smooth) that isn't going to kill me...
    Try finish sanding the edges, then brush on epoxy, and use an automotive spot putty to fill in any voids.
    Jul 2005
    298
    That might do it. Whilst I prefer spraying from the speed point of view, it's not real healthy without the right gear.
    I know someone who's using epoxy paints, so I might be able to get a 'sample' for testing.
    Do epoxy paints give off any dangerous fumes when painting with a brush?
    Not paint, just regular epoxy, preferably a thin type. Use it as a sealer, then prime and paint.
    Jul 2005
    298
    Ah OK.
    The only epoxy I usually see is in very small tubes in hardware stores (and is very expensive). I am aware you can get larger cans/drums of it, but it's not something I've ever noticed for sale. I'll have a hunt around.
    Mar 2007
    No easy way to get a mirror finish to mdf. Hard work will prevail, lots of
    sanding and filling. I use a waterbased filler, similar stuff to what you might
    use when grain filling for polish.
    Sep 2005
    1660
    Quote Originally Posted by sploo View Post
    Ah OK.
    Check out Westsystem.com and locate the nearest distributor. Its about as cheap an epoxy as you can buy in reasonable quantities. Works great too!
    They also have a fairly informative website..
    HTH
    Jerry
    JerryFlyGuy
    The more I know... the more I realize I don't
    Jul 2005
    298
    Many thanks Jerry, I'm following that up right now!
    Mar 2005
    103
    Ive found the best way to get a really smooth finish on the edges of mdf is to sand it really smooth to begin with and then seal it with a water/woodglue mix as ger suggested. then a denib sanding will leave a smooth edge. paint with a sandable primer, and you can wetsand the edges super smooth.
    Jul 2005
    298
    I have tried water/glue, but found the sides of the MDF showed through after painting (it takes a few weeks).
    Also, anything water based does tend to make the MDF move a little.
    Once I can get hold of some epoxy, I intend to try various combinations of it, 2 pack primer, and an MDF primer I've picked up. It could be a while, but I do plan to post the results when I'm done.
    Dec 2005
    1408
    Dear sploo,
    I'm sorry you had no luck with water/glue.
    Here is a link which gives a lot of information from lots of people about how to prime MDF. As you will see, opinions vary!
    http://www.woodweb.com/knowledge_bas...nel_Doors.html
    One more thing. I personally have never had any luck at all using water based primer on mdf.
    Best wishes
    Martin
  1. Paypal sucks
    By cncadmin in forum Community Club House
    Last Post: 04-12-2007, 05:55 AM
