587,744 active members*
2,700 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Renishaw Probe Offset is shorter now?
Results 1 to 13 of 13
    Jan 2006
    179
    I've always had the Renishaw probe in our machine, and it's offset has always been 5.5149. To the best of my knowledge, it's never been crashed. We've never ever replaced the tip on it. After making several parts that were coming out about .016 low in the Z, I checked the spindle probe offset, and it was indeed off. I recalibrated to the OTS on the table, and wouldn't you know it, the spindle probe offset is now 5.4995.
    What would or could cause the spindle probe offset to become less all of a sudden?
    Feb 2010
    1184
    Re: Haas Renishaw Probe Offset is shorter now?
    Quote Originally Posted by sanddrag View Post
    You said that you recalibrated the OTS. Did you verify that the stylus of the OTS was flat? Is the center of the stylus pitted from use? Did you verify that the gauge length of the calibration tool is correct?
    If none of these questions are an issue, then run your calibration sequence again, making sure that the machine is adequately warmed up.
    Good luck!
    Jan 2006
    179
    I did not recalibrate the OTS. I used the VQC routine for calibrate spindle probe length, where it takes the Renishaw work probe and touches it to the OTS. I'll sweep the OTS with an indicator and verify that it is still flat.
    Feb 2010
    1184
    You need to recalibrate the OTS, not just sweep it.
    Jan 2006
    179
    Ok, I recalibrated both through IPS, and now my work probe length offset is 5.6189. Substantially different from where it was originally, but perhaps it's because I'm referencing the spindle housing nose where the sunken socket head cap screws are, and perhaps when it was set up they referenced the part of the spindle that turns with the drive lugs on it. Would that be a difference between now and then?
    Still not sure why it ever changed by about .016 but, when I probe the work probe to the OTS through VQC, the offset is within .0002 of what it was when calibrating through IPS. Also, when I probe a tool, and I probe a known surface, the tool goes to the proper height of that surface within .0002, so I think I'm good.
    Could anything a technician may have done during a Preventative Maintenance procedure caused the spindle probe calibration to be off?
    Feb 2010
    1184
    Sometimes a probe system will go years without any issue and other systems seem to require calibration on a more regular basis. What causes it? There could probably be a whole physics lesson on why, but my opinion is that it is just due to the many various machine vibrations. I wouldn't dwell to much on it.
    Just remember that anytime you have something odd happening with the system with regards to it's accuracy, the first thing you should do is recalibrate and see if the problem is fixed.
    Feb 2012
    115
    Are your tools measuring the same as they were? It's easy to move the ots top if you are working around it and not paying attention, and it's slightly loose.
    Mar 2014
    133
    You have to recalibrate both systems. IPS and VQC
    Feb 2012
    115
    @HFOtech I'm not sure that is right, I rather think both use the same underlying renishaw routines.
    Mar 2014
    133
    In theory yes you're right, but I've seen on some rare occasions that you have to do calibrate both systems because it doesn't transfer over.
    Feb 2012
    115
    They both use 9802 and 9803 as near as I can tell.
    Mar 2014
    133
    Also, do you keep the probe in the tool changer or do you hand load it? If you hand load it are you calling up the right tool number before you start the probing process? I've seen some people calibrate the probe as the last tool in the carousel, but leave it out of the machine. Next thing you know you run tool 1 through whatever and you complete your part. So you still have the wrong tool in the spindle, but you take that one out and load the spindle probe. Which is looking at the wrong tool offsets for the probe. Just throwing that out there just in case.
    Feb 2012
    115
    I figured out the other day that my OTS was moving slightly. IMO the renishaw way of tightening the OTS to the base is faulty. To get the thing to quit moving with an indicator on it, I had to tighten the setscrews way beyond what the designers should ever have thought acceptable.
  1. Renishaw work probe offset
    By claudiu220405 in forum Haas Mills
    Last Post: 09-01-2014, 07:32 PM
  2. Replies: 0
    Last Post: 08-28-2014, 09:40 AM
  3. Replies: 2
    Last Post: 06-05-2014, 03:16 PM
  4. Haas VF-5 Renishaw OMP-40 probe
    By dackley05 in forum Haas Mills
    Last Post: 08-31-2011, 12:51 PM
  5. Haas Renishaw Probe
    By Tazzer in forum Haas Mills
    Last Post: 07-07-2009, 12:18 AM
