586,648 active members*
2,275 visitors online*
Results 1 to 9 of 9
    Jan 2017
    Solidcam POST Processor for Mach3 Turn
    Included is a Modified FANUC2013 Turn postprocessor for SolidCam, posted by some kind person on this forum. I don't remember exactly where i downloaded it.
    I sat down to make it work with my Mach3 lathe and Solidcam2015, studied the Gcode, and found what needed to bed fixed.
    I have done the following modifications to make it work with Mach3:
    Removed the program number with colons which made mach3 protest.
    Included missing spindle speed in a G98/G97 line, which made mach3 protest.
    Adjusted the startup and end coordinates to fit within my relatively small (14") lathes working area. ADJUST THESE TO FIT YOUR MACHINE!!!
    Swapped G2 and G3 because solidcam works above the part, and mach3 below the part. X and Z directions are the same, but arcs go the wrong way.
    Swapped arc direction by changing where the radius is output as negative vs positive, for the same reason as above. Puts the arc on the right side of the desired path.
    The post was tested by drawing up a test part, with inside and outside turning, arcs and angles in several directions with 2 tools in one operation.
    It ran fine without any problem, just loaded and pressed cycle start.
    Picture of part and simulation screenshot in mach3 included in the zip, posttest1/2/3.jpg
    I take no responsibility for any faults in the modified post. It works for me, and i hope it works for you as well.
    Have fun!
    Mar 2014
    1131
    Re: Solidcam POST Processor for Mach3 Turn
    Thanks for the info.
    I have a retrofitted lathe which is a simple 2 axis lathe. Spindle turns only one direction. Can I use your PP with it?
    Jan 2017
    Absolutely. Ny lathe is also a small retrofit, with manual diection change and manual speed select. Works fine.
    Feel free to ask if something is unclear.
    Quote Originally Posted by Azalin View Post
    Mar 2014
    1131
    That's great. I'll try it soon. Thanks
    Mar 2014
    1131
    Hi again,
    Exactly which lines do I need to modify?
    Mar 2014
    1131
    I edited the tool change position to X120, Y200. However after tool change it tried to go to minus coordinates and almost crashed the part. I guess there are more lines I need to edit.
    Mar 2014
    1131
    To be more specific, the first image is from SC. The second is from Mach3 with the gcode generated with your PP.
    Jan 2011
    i have tried this, i know its an old thread ,but it wont appear in the dropdown for turning post processors in solidcam2014 its only under milling
    any ideas?
    or is there an up to date version that works solidcam 2014 to mach3 turn
    cheers
    Jul 2009
    152
    I know this is an old one but, how do I adjust the lathes working area and where is it found?
  1. post processor for solidcam mach3 turn
    By shoke in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-11-2024, 05:25 PM
  2. Mach3 Turn Post Processor
    By kenwoodhf in forum Dolphin CAD/CAM
    Last Post: 02-17-2016, 04:30 PM
  3. solidcam mach3 4th axis post processor
    By mioduz in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-07-2014, 01:04 PM
