587,311 active members*
3,615 visitors online*
Results 1 to 12 of 12
    Oct 2010
    670
    Aluminum 7075 vs 6061
    Getting ready to do a production run of parts for a guy and he is using 7075. I'm used to running 6061 and these will be my first 7075 parts. Any suggestions on things that may jump out and bite me?
    Awall
    The Body Armor Dude - Andrew
    Nov 2013
    402
    Re: Aluminum 7075 vs 6061
    Nothing major to worry about.
    7075 is a little 'stiffer' than 6061, but it machines like a dream.
    May 2010
    327
    Quote Originally Posted by RussMachine View Post
    Ditto. I run quite a bit of 7075 and it runs great.
    WW
    Manufacturing & Development
    ThermaeCooling.com
    Sep 2013
    183
    7075 is much stronger than 6061. Stronger than some steels. But it cuts like a dream and is a lot less 'gummy' than 6061. You can sometimes cut dry or with a basic mist spray. Be wary of the stronger, sharper chips during cleanup.
    Aug 2009
    610
    7075 is nice to work with. I find that it requires less edge breaking and overall finishing work than 6061. It's the aluminum of choice for most of my personal projects.
    Mar 2009
    1863
    I make running gear for remote control race boats and I use 6061 for everything EXCEPT the rudder. I ONLY use 7075 for rudders. I am so adamant about using 7075 for my rudders, if you ask me to make them out of 6061, I'll ask you to have them made somewhere else.
    At the speeds some of these boats are traveling, I have seen rudders made from 6061 fold over causing the boat to crash. And it's not uncommon to have $2,500.00 ior even $3,000.00 nvested in one of these boats.
    Aug 2009
    610
    Dang Steve! How thick are those rudders typically? Sounds like a good spot to maybe deploy some grade 5 Titanium :-). Sorry to derail the thread, but that's pretty crazy to think about one of those boats grenading because of a rudder failure....definitely could bring a person to tears.
    Mar 2009
    1863
    Quote Originally Posted by pickled View Post
    Titanium would be great, but I doubt anyone would pay $100.00 for a rudder.
    Feb 2014
    72
    Something to add about 6061 vs 7075, while 7075s ultimate tensile strength is about 75% higher they have the same modulus of elasticity (stiffness) and it costs a fair bit more. On parts that I make stiffness is critical as I'm replacing steel suspension parts and FS is high.
    Not really related to the OP but when designing its always good to think about the part requirements.
    Mar 2009
    1863
    I start with 1/4 inch material for the mounting area and a finished rudder is .190 thick on the trailing edge and .015 thick on the leading edge.
    Mar 2008
    683
    I prefer machining 7xxx aluminum to 6xxx.
    Oct 2011
    134
    Same here, do quite a bit of 7075, only thing to add is that i use mist not flood.
    Cheers,
    .adrian
  1. Forged 6061-t versus 7075-t651
    By lourenco in forum Bending, Forging, Extrusion...
    Last Post: 07-13-2018, 01:51 AM
  2. Where to get Aluminium,. 6061, 7075 and other machinable alloys in Aus?
    By gregau in forum Australia, New Zealand Club House
    Last Post: 10-07-2016, 12:26 AM
  3. Alloy billet 6061 7075 supply
    By phantom1500 in forum Australia, New Zealand Club House
    Last Post: 03-15-2013, 06:11 AM
  4. 7075-T6 to 6061-t6 welding?
    By AMCTony in forum Welding Brazing Soldering Sealing
    Last Post: 02-05-2007, 04:24 AM
  5. 7075 Aluminum
    By mtechserv in forum Moldmaking
    Last Post: 03-28-2005, 05:27 AM
