I need machine parameter for Fanuc 6T if someone have it please tell me.
tanx.
tanx.
Here are parameters for a Mazak ST-15 with FANUC 6T (1982)
Al
The parameters for each make & model machine will be different. You can't just take a parameter list for one type of machine and enter it in another. Things like ballscrew pitch, servo motor type, options, etc. are all affected by the parameters. Try to find someone with the exact same machine and copy their parameters.
dear Mostafa
call me on 0098 0912 1970439 -
F.Sharifi
In all actuality, I could use the list of parameters and what they control as well! I don't know what manual this is in. I have an operators, maintenance and programmers manual for the 6T and there are snippets of parameters scattered throughout each, but not a comprehensive list....
hello sir,
i am zain ali from Pakistan.i am doing cnc maintenance last 12 years i want to go abroad for work can you help me to searching the job of cnc maintenance in iran or dubai or saudi araibia.can you send me the link.my e mail is [email protected]
What parameter number do you need the definition of?
Mark.
Dear Sir,
i have bought cnc lathe machine.
specifications:
Herbert Churchill Ltd
M/C Type HC 3/15
M/C No 918080
Div No 30080
Elect DRG E0A15453
Hyd DRG HAO 4026
Supply 415V/3ph
control:
Fanuc 6T
type A02B-0059-B401
serial no 1000085 date 1984-02
fanuc mechatronice S.A
Mother Board:
A16B-1000-0030/05C
PC Model-B:
A20B-0008-0440A
ROM:
A16B-1200-0150A
CRT/Puncher:
A20B-0008-0430A
BMU 64-1:
A87L-0001-001508I
Problem:
when i power on the control the dispaly of control(crt/mdi) unit show the green layers therefore i cant read any thing.
would you like to help me in this problems.
i shall be greatfull to you.
Blow some warm dry air into the crt for a time before powering up.Then check input voltages.Not had a lot of these problems with Fanuc monitors but common on GE`s.
Pull out the CRT base and econnect it If possible please try to check the Voltages on R G B cathode IF they are normal than you will have to replace the CRT . But I think this is a problem of Loose or rusty connection only. Because your manufacturer is the one of best in Industry
Regards
Prabhat
Hello to all.
I had a problem with an old fanuc OM controller. I tried to make DNC connection but my dnc software(cimco edit5) just sent the file to machine. I try to solve the problem but now i cant send file! at start the controller shows me error101 and when i clear the memory and put the input button to start sending, the lsk flashes on screan.
i am sure the connectors are ready, because i had send before.
could any one help me?
Hello to all
I had a problem with an old FANUC 6T controller.I make power on in the CRT Screen show alarm "607 PC''
I want to action this problem .
tank you to all.
I always wondered what part numbers the CRT/MDI's were for the various 6M and 6T controls were. Was there a 6P?
Maybe they are one of these:
A02B-0050-
A02B-0051-
A02B-0059-
A02B-0060-
A02B-0061-
A02B-0062-
There are probably others.. any ideas?
