585,938 active members*
3,393 visitors online*
Results 1 to 15 of 15
    Feb 2007
    2
    Machine parameter for Fanuc 6t
    I need machine parameter for Fanuc 6T if someone have it please tell me.
    tanx.
    Jan 2007
    22
    Here are parameters for a Mazak ST-15 with FANUC 6T (1982)
    Al
    Attached Files Attached Files
    Sep 2005
    767
    Machine parameters
    The parameters for each make & model machine will be different. You can't just take a parameter list for one type of machine and enter it in another. Things like ballscrew pitch, servo motor type, options, etc. are all affected by the parameters. Try to find someone with the exact same machine and copy their parameters.
    Feb 2007
    2
    Quote Originally Posted by Dan Fritz View Post
    Dear Dan Fritz
    Hello
    Actually I need the PARAMRTER DEFINITION i mean what is the function of each
    parameter if it is available would you please tell me.
    with best regards
    Mostafa
    Nov 2006
    925
    What parameter number do you need the definition of?
    Mark.
    Aug 2006
    93
    dear Mostafa
    call me on 0098 0912 1970439 -
    F.Sharifi
    Feb 2007
    67
    In all actuality, I could use the list of parameters and what they control as well! I don't know what manual this is in. I have an operators, maintenance and programmers manual for the 6T and there are snippets of parameters scattered throughout each, but not a comprehensive list....
    Dec 2008
    14
    Dear Sir,
    i have bought cnc lathe machine.
    specifications:
    Herbert Churchill Ltd
    M/C Type HC 3/15
    M/C No 918080
    Div No 30080
    Elect DRG E0A15453
    Hyd DRG HAO 4026
    Supply 415V/3ph
    control:
    Fanuc 6T
    type A02B-0059-B401
    serial no 1000085 date 1984-02
    fanuc mechatronice S.A
    Mother Board:
    A16B-1000-0030/05C
    PC Model-B:
    A20B-0008-0440A
    ROM:
    A16B-1200-0150A
    CRT/Puncher:
    A20B-0008-0430A
    BMU 64-1:
    A87L-0001-001508I
    Problem:
    when i power on the control the dispaly of control(crt/mdi) unit show the green layers therefore i cant read any thing.
    would you like to help me in this problems.
    i shall be greatfull to you.
    Nov 2006
    925
    Blow some warm dry air into the crt for a time before powering up.Then check input voltages.Not had a lot of these problems with Fanuc monitors but common on GE`s.
    Dec 2008
    14
    Quote Originally Posted by gridley51 View Post
    i cleaned all cards with dry cleaner bt still same problem
    Dec 2008
    1
    Hello to all.
    I had a problem with an old fanuc OM controller. I tried to make DNC connection but my dnc software(cimco edit5) just sent the file to machine. I try to solve the problem but now i cant send file! at start the controller shows me error101 and when i clear the memory and put the input button to start sending, the lsk flashes on screan.
    i am sure the connectors are ready, because i had send before.
    could any one help me?
    Dec 2008
    239
    Quote Originally Posted by nadlala View Post
    Dear Sir,
    specifications:
    M/C Type HC 3/15
    M/C No 918080
    Div No 30080
    Elect DRG E0A15453
    Hyd DRG HAO 4026
    Supply 415V/3ph
    control:
    Fanuc 6T
    type A02B-0059-B401
    Mother Board:
    A16B-1000-0030/05C
    PC Model-B:
    A20B-0008-0440A
    ROM:
    A16B-1200-0150A
    CRT/Puncher:
    A20B-0008-0430A
    BMU 64-1:
    A87L-0001-001508I
    Problem:
    Pull out the CRT base and econnect it If possible please try to check the Voltages on R G B cathode IF they are normal than you will have to replace the CRT . But I think this is a problem of Loose or rusty connection only. Because your manufacturer is the one of best in Industry
    Regards
    Prabhat
    Jul 2009
    1
    Hello to all
    I had a problem with an old FANUC 6T controller.I make power on in the CRT Screen show alarm "607 PC''
    I want to action this problem .
    tank you to all.
    Mar 2005
    816
    I always wondered what part numbers the CRT/MDI's were for the various 6M and 6T controls were. Was there a 6P?
    Maybe they are one of these:
    A02B-0050-
    A02B-0051-
    A02B-0059-
    A02B-0060-
    A02B-0061-
    A02B-0062-
    There are probably others.. any ideas?
    Oct 2013
    40
    Re: Machine parameter for Fanuc 6t
    hello sir,
    i am zain ali from Pakistan.i am doing cnc maintenance last 12 years i want to go abroad for work can you help me to searching the job of cnc maintenance in iran or dubai or saudi araibia.can you send me the link.my e mail is [email protected]
  1. Replies: 2
    Last Post: 01-26-2014, 03:56 PM
  2. Machine parameter edit procedure for FANUC 6T System
    By VENKATESH REDDY in forum Fanuc
    Last Post: 10-13-2011, 10:56 PM
  3. Fanuc 6M machine parameter
    By gowthu in forum Fanuc
    Last Post: 08-12-2010, 03:38 PM
  4. fanuc oi-mc system parameter help leadwell machine
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-07-2008, 04:58 AM
